Good to know about RC1. I had months ago disabled access to root via ssh. Even I have to ssh in as SU with a password. I was wondering if this exploit hack was seen by others, just a heads-up.
Duane KA1LM
Duane KA1LM
ANY port that you have open to the outside world is going to add to
the risk you enjoy (!) from being connected to the network. There
are well-known ports; in the U/Lin-UX world, the goldmine ports (ie
those which are reserved to the root group, are those port #s <
1024…and once you have root, all bets are off as to what you can
do.
That many people have their routers set up to automagically
establish persistent connections when any outbound traffic port is
opened, this means that if your machine is pwned and a rogue daemon
sets up a channel to a command and control system, YOUR machine is
part of a botnet…doing who knows what.
In 7 years of running an asterisk box, I have NEVER had a reason,
while away from the site, of having to log in to do something. Now,
it may be different if your box is on a mountain top and
inaccessible for 4 months of the year…but, my rule is, if you can
drive there, then I don’t enable shell access from the outside. I
turn off, on my router, PnP. I deny ANY to ANY inbound connections
as the default ACL. My boxes have static IPs on the inside of a
NAT, and ports are routed to specific host/ports. Fail2ban is
running, and, as a luxury, my logs are NOT stored on the machines
that ARE accessible; the first thing that a miscreant is going to do
is try and erase system log entries of what they’ve done. So…how to do those things that you have to do administratively?
Think belt and suspenders. One of the nice things about asterisk is that you can script almost
anything both inside the application as well as the operating system
to respond to DTMF. Now, I realize that not everyone has this
ability, but, being all my boxes are accessible via the net in some
manner…I have a receive-only node on an oddball frequency in a
second location locally, which also has an echolink node
assigned…and have scripted the admin functions I use on a
regular basis. Things like reboot the box…restart asterisk…even
down to connect and disconnect nodes (ie command *node#3 or *node#1
to connect or disconnect node#), etc.
Add in the fact that you can have control over the GPIO pins on the
DMK and RIM URIs, and you can even do relay-driven (I like
electromechanical stuff) things: turn on fans, turn off fans, turn
on power, turn off power…the possibilities are endless, if you
think through just what it is that you need to when you supposedly
have to log in via a shell. Haven’t quite worked out how to mount a
cdrom that has a clonezilla image of a fresh box to restore a system
from a DTMF command…but, I’m sure with some hacking, even that
could be done to remotely restore a system that HAS been trashed. In my opinion, we have to get away from thinking that we need to
have terminal access to what is (or should be) essentially an
appliance that controls radios. And, no, I’m not thinking that a
web interface is necessarily the way to go either.
On 6/16/2017 8:56 AM, DuaneVT . wrote:
Good to know about RC1. I hadmonths ago disabled access to root via ssh. Even I have to ssh
Duane KA1LM
Bryan you can run a DD command on a backup hard drive where you store your images to flash your running drive… Typically speaking most of your os is in the memory so you won’t affect much until the reboot… Better hope you setup the boot manger correctly but it can be done via dtmf and shell script if you really wanted to. Its the same principle as doing a rm -r / command… But yes this can be technically done via dtmf however i don’t recommend it… #I<3Shellscripts
Duane KA1LM
ANY port that you have open to the outside world is going to add tothe risk you enjoy (!) from being connected to the network. There
do.That many people have their routers set up to automagicallyestablish persistent connections when any outbound traffic port is
part of a botnet…doing who knows what.In 7 years of running an asterisk box, I have NEVER had a reason,while away from the site, of having to log in to do something. Now,
is try and erase system log entries of what they’ve done.So...how to do those things that you have to do administratively?Think belt and suspenders.
One of the nice things about asterisk is that you can script almostanything both inside the application as well as the operating system
to connect or disconnect node#), etc.Add in the fact that you can have control over the GPIO pins on theDMK and RIM URIs, and you can even do relay-driven (I like
could be done to remotely restore a system that HAS been trashed.In my opinion, we have to get away from thinking that we need tohave terminal access to what is (or should be) essentially an
Loren Tedford (KC9ZHV)
Phone:
Fax:
Email: lorentedford@gmail.com
Email: KC9ZHV@KC9ZHV.com
To restore a node to its original state can be done by a simple script and the script can be called by dtmf, just need some preparation first…
first when your node is as it should be, all configured tested and secur. do a dd command to dump an image of your system.
to find what you need to dump do first a fdisk -l command. this will list all the filessystem on the machine. find the disk you want to backup, let say sda. you wil have a list of all the partition on sda, sda1, sda2… now take note of the last used sector of the last partition on the disk. add one to it and take the bs or block size value,usely 512 bites.
now the dd command type dd if=/dev/sda of= /mnt/ what ever the disk you mounted to back your image/ nodexxxx.img count=(the number of the last used block on your last partitio plus 1 , we calculate it earlier) bs=the block size found on the fdisk command usely 512 then it enter.
this will make a file named nodexxxx.img and will be the smaller it can be since we stop copying the data 1 block after the last used block. you can then tar and gz it. but I find it not usefull for such utility we do now.
then in the script you call by dtmf make asterisk stop and call the command dd if=/mnt/where is your backup file/ nodexxxx.img of=/dev/sda
then do a reboot and your node is back as itwas when you did the first image…
hope it helped someone…
Pierre
VE2PF
Duane KA1LM
