Devstr keep on changing (ASL multi node)
I configured two nodes with simpleusb in my dell wyse 3040. The device string keep on changing and when I reboot the system, it will not be the same with the devstr value in the simpleusb.conf anymore and it causes error since device string is not found.
When I leave the devstr empty, the assignment of the two usb ports sometimes were swapped.
Is there a way that the device string given by the OS become static? The nodes I am trying to configure will automatically connect to different node numbers.
