Debian 12 ASL3 Pseudo node failing
Hi all,
I've just built a new Debian 12 install with ASL3 to use as node hub, however after configuration with asl-menu the node fails to start with the below message.
debian*CLI> rpt localnodes
Node
debianCLI> core set verbose 5
Console verbose was OFF and is now 5.
debian
CLI> module reload app_rpt.so
Module 'app_rpt.so' reloaded successfully.
-- Reloading module 'app_rpt.so' (Radio Repeater/Remote Base Application)
[2025-05-29 14:42:14.927] WARNING[985]: app_rpt.c:5659 rpt_master: rpt_thread restarted on node 618035
-- Re-Loading config for repeater 618035
[2025-05-29 14:42:14.929] WARNING[1003][C-00000002]: chan_dahdi.c:4418 dahdi_open: Unable to open '/dev/dahdi/pseudo': No such file or directory
[2025-05-29 14:42:14.929] ERROR[1003][C-00000002]: chan_dahdi.c:13762 duplicate_pseudo: Unable to dup channel: No such file or directory
[2025-05-29 14:42:14.929] ERROR[1003]: app_rpt/rpt_bridging.c:231 __rpt_request: Failed to request dahdi/pseudo
[2025-05-29 14:42:14.929] WARNING[1003]: app_rpt.c:2829 disable_rpt: Disabled broken repeater 618035
Why is this failing?
Dion.
Disregard.. Looks like it was an issue with secure boot.
Dion.
If you didn't find it:
