DAHDI timing issues
Hello
Apparently there is something amiss regarding the timing of the DAHDI module on ASL 1.01.I get this "skipping"noise on this image.
I did try DAHDI DUMMY&it does help a bit but its not a complete install.I get this message&cannot proceed until this kernel installed
" You do not appear to have the sources for the 4.9.80-v7+ kernel installed."
What repository can I go to get this kernel?
Pete
KD2ARB
try doing this:
sudo apt-get install linux-headers-$(uname -r)
if you are running on a raspberry pi the command is :
sudo apt-get install raspberrypi-kernel-headers
Did you read and follow the readme file when you downloaded the image?
Login: repeater
Passsword: allstarlink
SSH port: 22
User repeater has sudo privileges (sudo -s)
There may have been updates to the operating system and AllStarLink since this image was built.
Run the following commands after the first time you boot.
sudo apt-mark hold raspberrypi-kernel-headers raspberrypi-kernel
sudo apt-get update
sudo apt-get upgrade -y sudo reboot
at the # prompt run "asl-menu" to setup your node.
Marshall - ke6pcv
Sent from my iPhone
On Apr 6, 2020, at 1:10 PM, Pete via AllStarLink Discussion Groups noreply@community.allstarlink.org wrote:
KD2ARB
    April 6
Hello
Pete
KD2ARB
