OK, I think it worked but won't be able to try and boot till tonight. It did
make teh CF and is a bit over 121MB total.
To make it work, I nuked the sudo -E parts and had to make a link from mkdosfs
to be mkfs.msdos. This one also choked on grep, and my way was to download
the file to my web server and get it from there. Had to do same for
lm-sensors.
I am working on a TEST D945 build also. The instructions imply some scripts are going to run after first boot. I do not seem to have any asterisk related files in the test build I downloaded and installed.
I am assuming I need to download and build the allstar files ?? the directions speak nothing of this that I found.. but maybe I am doing something wrong?? The D945 box boots to a root login prompt and stops there. After searching around inside I see no install or config scripts to fetch the needed files..
I am guessing I need to wget these files???
Any input would be helpful to me ....
The CF build is fine and the files copied were 131 or so mb... but looks like just the Limey Linux OS build with no AllStar files..
Doug
KD8B
lm-sensors.
Doug
KD8B
from mkdosfs
lm-sensors.
There hasn't been much requests for the d945gclf version of Limey Linux.
All 1.0.7 versions are test versions right now until a few key app_rpt.c
bugs are fixed. Test versions are usually for testing only.
I just uploaded cfimg-d945gclf-1.0.7-test5.tar.gz, and deleted the older
test version. This has asterisk installed and should prompt you at
first boot.
