Afternoon all,
So as part of my VOX demonstrator build (see other thread) I need to have a second node so that I can demonstrate DTMF based linking - just like the guy that invented the first telephone - he had to build a second!
And the issue that I see must be something I’m doing in config as I have different PIs , soundfobs, and even tried beta 2 then regressed back to stable 1 as I am seeing it on both builds.
Problem summary - circa once a minute asterisk restarts on my second node. taking all registrations with it .
No matter how high I set console verbosity When it crashes I am booted out so no meaningful info can be gleaned from the console session.
Tailing /var/log/asterisk/messages I see (The ficticious node number is an off-grid private test network) :
[Feb 4 15:17:46] WARNING[19202] chan_usbradio.c: Possibly stuck USB read channel. [usb_16335]
[Feb 4 15:17:46] WARNING[19202] chan_usbradio.c: Nope, USB read channel [usb_16335] wasn’t stuck after all.
[Feb 4 15:18:37] NOTICE[19215] dnsmgr.c: Managed DNS entries will be refreshed every 300 seconds.
[Feb 4 15:18:37] NOTICE[19215] cdr.c: CDR simple logging enabled.
[Feb 4 15:18:37] NOTICE[19215] loader.c: 57 modules will be loaded.
[Feb 4 15:18:37] NOTICE[19215] ./xpmr/xpmr.c: xpmr rxlpf: 0
[Feb 4 15:18:37] NOTICE[19215] ./xpmr/xpmr.c: xpmr rxhpf: 0
[Feb 4 15:18:37] NOTICE[19215] ./xpmr/xpmr.c: xpmr txlpf: 0
[Feb 4 15:18:37] NOTICE[19215] ./xpmr/xpmr.c: xpmr txhpf: 0
[Feb 4 15:18:37] NOTICE[19221] app_rpt.c: Normal Repeater Init 16335
[Feb 4 15:18:37] WARNING[19238] chan_usbradio.c: Loaded parameters from usbradio_tune_usb_16335.conf for device usb_16335 .
[Feb 4 15:18:37] WARNING[19237] chan_usbradio.c: Possibly stuck USB read channel. [usb_16335]
[Feb 4 15:18:37] WARNING[19237] chan_usbradio.c: Nope, USB read channel [usb_16335] wasn’t stuck after all.
[Feb 4 15:19:27] NOTICE[19245] dnsmgr.c: Managed DNS entries will be refreshed every 300 seconds.
[Feb 4 15:19:28] NOTICE[19245] cdr.c: CDR simple logging enabled.
[Feb 4 15:19:28] NOTICE[19245] loader.c: 57 modules will be loaded.
[Feb 4 15:19:28] NOTICE[19245] ./xpmr/xpmr.c: xpmr rxlpf: 0
[Feb 4 15:19:28] NOTICE[19245] ./xpmr/xpmr.c: xpmr rxhpf: 0
[Feb 4 15:19:28] NOTICE[19245] ./xpmr/xpmr.c: xpmr txlpf: 0
[Feb 4 15:19:28] NOTICE[19245] ./xpmr/xpmr.c: xpmr txhpf: 0
[Feb 4 15:19:28] NOTICE[19251] app_rpt.c: Normal Repeater Init 16335
[Feb 4 15:19:28] WARNING[19268] chan_usbradio.c: Loaded parameters from usbradio_tune_usb_16335.conf for device usb_16335 .
[Feb 4 15:19:28] WARNING[19267] chan_usbradio.c: Possibly stuck USB read channel. [usb_16335]
[Feb 4 15:19:28] WARNING[19267] chan_usbradio.c: Nope, USB read channel [usb_16335] wasn’t stuck after all.
nothing in the event log.
I have seen this issue across 2 different PIs , with 3 different soundcards and 2 different builds
NODE 1 - Beta 2.x - present after 5 days
NODE 1 - Stable 1.x - now clear and stable for 3 consecutive days
NODE 2 - Stable 1.x - present on day 1 , still present
NODE 2 - Beta 2.x - not tested
Node 1 is a Pi3B
Node 2 is a Pi2B
I am convinced its config, and its clearly easily repeatable as I’ve managed to do it twice on 2 nodes.
Has anyone else seen this / root caused the challenge please ?
Its not CPU / RAM as top thinks I’m only consuming 2.8% CPU and less that 50% RAM
any clues ?
Regards
BB
