Cw id changed from dashboard
It is possible to change the CW ID by changing it from the allstar.org dashboard.
That setting is internal to the software and loaded at boot time.
So a change requires asterisk restart.
So, the answer is no.
As @Mike said, it is a local setting. On you node pc/pi, open the rpt.conf file via asl-menu or directly by typing
sudo nano /etc/asterisk/rpt.conf
Then scroll to your node settings under [node number] and change idrecording = |i(CWid) as per your requirement. Save and restart asterisk.
