Custom Sd card copy asl3 for p3 torun digigate
Last chance need a custom made copy asl3 for p3 torun digigate been trying for 2 weeks now still cant get this thing to work as the software issue OS if not this project going to dump.
Are you asking about installing TORUN Digi Gate? If so, we cannot help - you'd need to ask the author. TORUN DiGi Gate V2 – Best AllStarLink Interface with OLED Display | Made in Bangladesh
There customer help support is different time and hardly answer.
Just throwing this out there, I have no familiarity with this vendor, but looking at the website, that looks like basically a re-arranged SHARI PiHat. Just for shits and giggles, try setting it up according to the SHARI PiHat instructions (the sw install part) on the SHARI group on groups.io. Worst that can happen is it won't work...
(instructions for ASL3 are in the files section, last I looked)
Tried and not working
It was worth a shot.
If anyone's going to try to help you over here, you're going to need to provide more information. Like, what is working? What is not? Were you able to install Debian and ASL completely? Can you log in?
I googled the guy's support and got a YT video that looks nearly identical to setting up a SHARI. He seems to skip past installing Debian and ASL, but instructions for that are in our manual.
Technically 1st thing the OS have problem communicating on the HAT this was on my previous post /dev/serial0 -> ttyS0 right now and it should be like this /dev/serial0 -> ttyAMA0 2nd if config.txt modify HAT will be detected but another issue is when on CLI you can PTT the hat but no audio coming or out of of the hat mean you cant adjust the audio or dtfm the hat for some reason.
There are NO problems running ASL3 with the Torun DigiGate V2/ V3 boards at all, ASL3 is running perfectly for me.....
