Custom NodeNames
I have written a shell script to create custom node names to replace
the announcing of nodes by their node number to the “callsign”
configured for each node on the system. Its 2 parts. First uses a
php script to download all the AllStar Node data and saves as txt
file called nodenames.
I save mine as 'getnodes.php'. The code can be found here:
After this runs, I run the second script:
I save mine as ‘nodenames.sh’. The code can be found here:
This script looks up the node number and finds the callsign, it then
creates a .ulaw file using the letters and digits found in the
AllStar systems. No TTS! It saves all the ####.ulaw files in Now when a node connects or disconnects, its announces a callsign
instead of a node number.
http://pastebin.com/cSCuAZnS
http://pastebin.com/AWtPpYjY
/var/lib/asterisk/sounds/rpt/nodenames.
-- Marshall Dias
Ottumwa, IA EN31ta
4SQRP #310
Marshall,
Looks interesting. On systems that have either lsnodes or allmon the astdb.txt file should already exist and is updated daily. It might be better to use that file for the second script if it exists. That would avoid unnecessary reads from the database and having yet another astdb.php file on the system. The astdb.php file has changed recently also and has better error detection, retry support, and it sorts. Just a suggestion.
Also I have a simple combine script I include in the BBB and RPi2 release that simply combines the gsm files with like this
cat file1.gsm file2.gsm file3.gsm > node.gsm
As long as all files type are the same there is no need to do any conversion. So maybe ffmpeg is not needed?
73 Doug
WA3DSP
Date: Mon, 17 Aug 2015 16:08:06 -0500
To: app_rpt-users@ohnosec.org
Subject: [App_rpt-users] Custom NodeNames
I save mine as 'nodenames.sh'. The code can be found here:
AllStar systems. No TTS! It saves all the ####.ulaw files in /var/lib/asterisk/sounds/rpt/nodenames.
-- Marshall Dias
Ottumwa, IA EN31ta
4SQRP #310
Hmmm…
Your getnodes.php is a line-for-line copy of my one version back astdb.php from allmon2. Allmon is open source and anyone is welcome to use parts of it as they see fit. However, vaguely claiming it’s your code is less than forthcoming. It’s brain dead simple code and I’m not claiming it’s my stolen master piece. It’s just low you imply that you wrote it.
On Mon, Aug 17, 2015 at 2:08 PM, W0OTM w0otm@w0otm.com wrote:
-- Marshall Dias
Ottumwa, IA EN31ta
4SQRP #310
Tim
Tim, if you feel you need credit for a few lines of code…then Im happy do send a mass email put to everyone on this list to announce I used your old code.
But, no where in the astdb.php file in my raspberry pi distro from the UK AllStar Group is your name listed. Nowhere is there an indication of who the author is…so, I will take your word that you deserve credit…I’ll get the plaque ordered:)
-- Marshall Dias
Ottumwa, IA EN31ta
4SQRP #310
Tim
Marshall,
I certainly was not criticizing your work, just making a few suggestions. If you are using the RPi2 (or BBB) then the astdb.txt file is located in /var/log/asterisk updated by a cron entry daily. You could simply read it from there. You do not have to create another copy of astdb.php.
Also I was looking for your comments on the ffmpeg. Why is that needed? Are the file types different that you are combining? You could just cat them together if they are all one type and just play them. gsm files will play as well as ulaw. You could also use sox to adjust the volume. There are examples of that in the scripts on the RPi2.
I think this would be a worthwhile script to maybe include in the RPi2/BBB image. It just needs a little refinement.
73 Doug
WA3DSP
Subject: Re: [App_rpt-users] Custom NodeNames
Date: Mon, 17 Aug 2015 22:29:34 -0500
To: doug@crompton.com
Everyone has an opinion, you are certainly entitled to yours. In the AllStar raspberry pi image I downloaded, it didn’t contain a solution for what I was trying to solve. What I made works well for me and I’m happy with it. Maybe others will see value in it as well.
Best regards
md
Sent from my iPhone
On Aug 17, 2015, at 8:03 PM, Doug Crompton doug@crompton.com wrote:
Marshall,
73 Doug
WA3DSP
-- Marshall Dias
Ottumwa, IA EN31ta
4SQRP #310
I haven't looked at this yet, but does it check for node ID files so that it doesn't override ones you already have for specific nodes? For instance, ones for the WAN system, let's say. If it doesn't check for those, maybe another addition?
Buddy Brannan, KB5ELV - Erie, PA
Phone: 814-860-3194
Mobile: 814-431-0962
Email: buddy@brannan.name
On Aug 17, 2015, at 11:59 PM, Doug Crompton <doug@crompton.com> wrote:
Marshall,
73 Doug
WA3DSP
Everyone has an opinion, you are certainly entitled to yours. In the AllStar raspberry pi image I downloaded, it didn't contain a solution for what I was trying to solve. What I made works well for me and I'm happy with it. Maybe others will see value in it as well.
Best regards
md
Sent from my iPhone
On Aug 17, 2015, at 8:03 PM, Doug Crompton <doug@crompton.com> wrote:
Marshall,
73 Doug
WA3DSP
I have written a shell script to create custom node names to replace the announcing of nodes by their node number to the "callsign" configured for each node on the system. Its 2 parts. First uses a php script to download all the AllStar Node data and saves as txt file called nodenames.
I save mine as 'getnodes.php'. The code can be found here: getnodes.php - Pastebin.com
I save mine as 'nodenames.sh'. The code can be found here: nodenames.sh - Pastebin.com
This script looks up the node number and finds the callsign, it then creates a .ulaw file using the letters and digits found in the AllStar systems. No TTS! It saves all the ####.ulaw files in /var/lib/asterisk/sounds/rpt/nodenames.
Now when a node connects or disconnects, its announces a callsign instead of a node number.
Marshall Dias
Ottumwa, IA EN31ta
4SQRP #310
_______________________________________________ App_rpt-users mailing list App_rpt-users@ohnosec.org http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users To unsubscribe from this list please visit http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users and scroll down to the bottom of the page. Enter your email address and press the "Unsubscribe or edit options button" You do not need a password to unsubscribe, you can do it via email confirmation. If you have trouble unsubscribing, please send a message to the list detailing the problem.
Tim, I wrote ALL the code for the AllStarLink Web Configuration Portal years ago. NOWHERE is it documented that I authored it. You don’t see me crying over not getting credit for my contributions!
It’s really ridiculous that you are pissing and moaning over a few lines of code…now that you’ve made a BIG stink, we ALL now know you authored the astdb.php script (although it’s not documented in the actual file anywhere, I’ll have to take your word for it)
EVERYONE give Tim a round of applause!
I will never offer another contribution to this project EVER again. Jim Dixon, mark my word! EVER!
-- Marshall Dias
Ottumwa, IA EN31ta
4SQRP #310
Tim
Ha! Your name is all over the the AllStar portal code. And so is Jim’s name.
Sent from my iPhone
On Aug 17, 2015, at 9:11 PM, Tim Sawyer tisawyer@gmail.com wrote:
Hmmm…
-- Marshall Dias
Ottumwa, IA EN31ta
4SQRP #310
Tim
Tim
Nope, once again you are wrong. Nowhere on the site where I got my RP2i image from does not indicate where allmon2 was sourced from…I’ve never even heard of allmon2 before you crying like a baby! Or that you were the author of it.
I really hope you are getting whatever it is you are needing though all of this…all this hub hub over a nodename script…
I sure got what I needed…reassurance that nothing has changed in the ham radio community. Still the same old drab folks in desperate need of attention and reinforcing their value in the hobby.
If it wasn’t for people all the thankless people in this hobby, you wouldn’t have a platform to cry on!
But, no where in the astdb.php file in my raspberry pi distro from the UK AllStar Group is your name listed. No where is there an indication of who the author is…so, I take you word that you deserve credit…I’ll get the plaque ordered:)
Sent from my iPhone
Hmmm…
-- Marshall Dias
Ottumwa, IA EN31ta
4SQRP #310
Tim
Tim
Tim,
No one gives a poop about about some code that you “claim” you wrote. Had the code been commented with your name, I could have given credit. But since there was nothing, it was impossible for me to know who wrote it. Since your name is NOWHERE in the file, I’m assuming you are claiming ownership of someone else’s work.
With uncommented, open source code, I don’t give a shit about worrying about stroking some arrogant douchbag’s ego. I don’t care what you think. I don’t care how you perceive my contribution. If you can’t see the intention of my contribution, then that’s YOUR problem.
#noonecares
Sent from my iPhone
On Aug 17, 2015, at 11:43 PM, Tim Sawyer tisawyer@gmail.com wrote:
The UK, you got it from a UK site? Well I’m impressed my code is getting around the world. Ok, I’ll take the hit for not putting my mark anywhere in the code but I was not and am not looking for a plaque :wink: Just so you know it came from here https://github.com/tsawyer/allmon2. Doug did ask me if he could distribute it with his RP2 code and I think it’s mentioned somewhere on his site.
I just think you should be more careful about your claims.
Sent from my iPhone
Hmmm…
Tim
-- Marshall Dias
Ottumwa, IA EN31ta
4SQRP #310
Tim
Tim
You kiss your mother with that mouth?
Can we try to act like grown ups? Please?
Regards,
Jim N7HQZ
Sent from my iPhone
Sent from my iPhone
Hmmm…
Tim
-- Marshall Dias
Ottumwa, IA EN31ta
4SQRP #310
Tim
Tim
