Curious about RepeaterPhone "public authentication"
I’m on Android but curious about the iOS app RepeaterPhone.
I spoke to a ham on 80m and he mentioned talking to friends in Santa Barbara K6TZ club using ASL and this app yet he has no node or account on another node. I think he does have a node number but I cannot locate his call sign in the nodes list.
The app description says-
" AllStarLink Support
Connect to AllStarLink nodes using public authentication or node-specific credentials"
How does this work?
73-
Clifford - KK6QMS
I believe he is using an attachment to the web transceiver but I could be wrong.
You need to contact the App’s support with questions.
You have always been able to do something similar using a sip phone app directly to the node/server. After all, the system rides on a phone PBX.
I use Zoiper to implement what Mike just suggested,
Bob
K6ECM
Reaching out to the author of the software is the best bet to get app specific information, I can tell you that all RepeaterPhone needs is a valid allstarlink web portal account in order to work. To use, you simply supply the web portal credentials to the app and viola, you are online and ready to go.
Hope that helps.
Jim, K6JWN
Hi, RepeaterPhone developer here.
There are generally three ways to authenticate when connecting to an AllStarLink node:
  1. DNS based authentication. When nodes come online, they register themselves with the ASL DNS system. When one node A requests to connect to node B, node B will query DNS for the details about node A. If the details match, node A is considered authenticated and trusted to connect.
  2. IAX local authentication. In this scheme, an IAX client presents a username and password that must match credentials that are configured in the ASL config file. If the credentials match, the client is authenticated and may connect.
  3. IAX “allstar-public” authentication. Also called “web transceiver” This is a variation on the username and password above. However, instead of the individual user credentials being stored locally in the ASL config file, the IAX client logs in to the allstarlink.org website and obtains a token. Then, when the client connects to a node, it presents the user’s callsign and token. The node will query allstarlink.org to see if the credentials are valid. If the query is successful, the client is authenticated and may connect.
RepeaterPhone supports the latter 2 mechanisms. The ‘allstar-public’ method is the most convenient for a lot of users because, since the verification authority (allstarlink.org) is centralized, it doesn’t require the node admins to manually add an entry for everyone that might want to connect.
I have just purchased Repeaterphone and installed on my iPad using my Allstar and Echolink accounts. Very good app with one moan. When trying to connect to some nodes eg HUBNET in UK an error message appears “Rejected: No authority found” other nodes I have no problems at all and connect without any issue??
What do I have to do to sort this matter out
Brian
Maybe ask the HUBNET folks?
Thanks I will give that a try
Hubnet in the UK does not support iax-client phone apps such as RepeaterPhone.
EchoLink is supported though.
Hello, on Android is it possible to do the same: connect on a public Allstarlink node via the AllStar server ? On DVSwitch ? Which parameters do we need to enter ? Thank you.
You should really read the DVSwitch Mobile documentation on groups.io for that answer (the how to would take multiple pages to answer your question) There’s 3 separate modes DVSwitch can connect to Allstar with, regular IAX, Web Tranceiver and Node Mode. On top of that, there’s various scenarios/variables. But make a long story short, yes. Yes you can.
Droidstar also works with IAX and WT modes.
What you are looking for in DVSwitch Mobile, which is the closest analog to how Repeaterphone works, is WT mode. The quickest way to get there is by long pressing on the D key on the virtual keypad. From there, you go to “enter WT setup”, put in your call and password for allstarlink.org, get a token, and then “enter WT mode”. From that point, you should be able to dial any node number that supports WT.
DVSwitch Mobile also has Node Mode, which allows you to register as a node number. This is a little more difficult to set up, but sometimes will get you on nodes that WT doesn’t.
I can’t find the user guide at the moment. I think it’s possibly on the DVSwitch groups.io subgroup for DVSM.
Hello, the WT (web transceiver) config is the solution I was looking for ! It works. Thank you guys.
