-----Original Message-----
Sent: Sunday, March 07, 2010 6:45 PM
To: Jann; app_rpt mailing list
Subject: RE: [App_rpt-users] CTCSS and carrier squelch
I verified your report and indeed it was only putting out the
default tone. I located and fixed the problem.
You still have to specify a default CTCSS tone (which will be
transmitted whether there is an input or not, and whether or
not there is CTCSS tone on the input).
I just sent the new software to Steve RoDgers and he will put
it in SVN later this morning.
JIM
> From: jann@gmx.de
> To: telesistant@hotmail.com; app_rpt-users@qrvc.com
> Subject: Re: [App_rpt-users] CTCSS and carrier squelch
> Date: Sun, 7 Mar 2010 15:57:47 +0100
> Hi Jim,
> I set 88.5 Hz now as a default CTCSS-tone:
> hdwtype=0
> rxboost=1
> rxctcssrelax=1
> txctcssdefault=88.5
rxctcssfreqs=67.0,71.9,74.4,77.0,79.7,82.5,85.4,88.5,91.5,94.8,97.4,10
> 0.0,10
3.5,107.2,110.9,114.8,118.8,123.0,127.3,131.8,136.5,141.3,146.2,151.4,
> 156.7,
162.2,167.9,173.8,179.9,186.2,192.8,203.5,210.7,218.1,225.7,23
3.6,241.8,250.
> 3
txctcssfreqs=67.0,71.9,74.4,77.0,79.7,82.5,85.4,88.5,91.5,94.8,97.4,10
> 0.0,10
> 156.7,
3.6,241.8,250.
> 3
> rxctcssoverride=1
> carrierfrom=dsp
> ctcssfrom=dsp
> rxdemod=flat
> txprelim=yes
> I'm able to open the repeater with any or none subtone. The
repeater
> is sending 88.5 Hz subtone all the time. It doesn't matter which
> subtone I use on my handheld.
> I want the repeater to send out the subtone I use on my
handheld, but
> it doesn't.
> I'm currently at the repeaters site and connected to your
repeaters.
> Maybe we can have a short chat on RF.
> Thank you,
> 73,
> Jann
>> From: Jim Duuuude [mailto:telesistant@hotmail.com]
>> Sent: Sunday, March 07, 2010 3:22 PM
>> You have to set a txctcssdefault frequency. If you dont want PL
>> unless someone is encoding it, then include "itxctcss=yes"
>> in app_rpt.c (in the clause for the node), but you still have to
>> specify some tx default frequency whether you ever use it or not.
>>> From: jann@gmx.de
>>> Date: Sun, 7 Mar 2010 06:55:47 +0100
>>> Hello Jim,
>>> thank you for the quick response. I did try the new
>> revision 569, but
>>> it doesn't work. My config:
>>> hdwtype=0
>>> rxboost=1
>>> rxctcssrelax=1
>>> ;txctcssdefault=71.9
>> 0
>>> 0.0,10
>>> 156.7,
>> 3.6,241.8,250.
>>> 3
>> 0
>>> 0.0,10
>>> 156.7,
>> 3.6,241.8,250.
>>> 3
>>> rxctcssoverride=1
>>> carrierfrom=dsp
>>> ctcssfrom=dsp
>>> rxdemod=flat
>>> txprelim=yes
>>> The repeater can be opened now without a subtone. Unfortunately
>>> subtones will not be detected and regenerated by the repeater or
>>> simply passed through the repeater. Any ideas?
>>> Tnx,
>>> 73,
>>> Jann
>>>> Sent: Saturday, March 06, 2010 6:05 PM
>>>> A reasonable and easy request. I went to great extremes (sarcasm
>>>> intended) to make a 1 line change in chan_usbradio to
accommodate
>>>> this need.
>>>> A new copy of chan_usbradio.c will be posted to the SVN
>> later today
>>>> once Steve gets home and does it.
>>>> It will add the "rxctcssoverride" parameter to usbradio.conf,
>>>> allowing the rx CTCSS to default to off. (you have to put
>>>> "rxctcssoverride = yes"
>>>> in the file.
>>>> You then specify your CTCSS tones like you would normally
>> (as if you
>>>> were going to require them for access), but the receiver
will not
>>>> require any tone to actually receive.
>>>> JIM WB6NIL
>>>>> From: jann@gmx.de
>>>>> To: app_rpt-users@qrvc.com
>>>>> Date: Sat, 6 Mar 2010 17:17:19 +0100
>>>>> Subject: [App_rpt-users] CTCSS and carrier squelch
>>>>> Hello,
>>>>> our repeater is in "carrier squelch"-mode. Since there is
>>>> much traffic
>>>>> on our repeater we are used to use different subtones for
>> different
>>>>> user groups just for the initial call to request a group
>> member to
>>>>> continue the qso without subtone (so nobody else in the
>>>> group will be disturbed).
>>>>> Unfortunately this seems to be impossible. We tried these
>>>>> configurations in
>>>>> usbradio.conf:
>>>>> #1 (we tried "0" in rxctcssfreqs/txctcssfreqs in CTCSS
dsp-mode)
>>>>> hdwtype=0
rxctcssfreqs=0,67.0,71.9,74.4,77.0,79.7,82.5,85.4,88.5,91.5,94.8,97.4
>>>>> 100.0,
>>>> 103.5,107.2,110.9,114.8,118.8,123.0,127.3,131.8,136.5,141.3,14
>>>> 6.2,151.4,156.
7,162.2,167.9,173.8,179.9,186.2,192.8,203.5,210.7,218.1,225.7,233.6,2
>>>> 4
>>>>> 1.8,25
>>>>> 0.3
txctcssfreqs=0,67.0,71.9,74.4,77.0,79.7,82.5,85.4,88.5,91.5,94.8,97.4
>>>>> 100.0,
>>>> 6.2,151.4,156.
>>>> 4
>>>>> 1.8,25
>>>>> 0.3
>>>>> carrierfrom=dsp
>>>>> ctcssfrom=dsp
>>>>> rxdemod=flat
>>>>> txprelim=yes
>>>>> #2 (we tried to disable CTCSS)
>>>>> hdwtype=0
>>>>> carrierfrom=dsp
>>>>> ctcssfrom=no
>>>>> rxdemod=flat
>>>>> txprelim=yes
>>>>> Is there a way to pass CTCSS tones through the repeater
>> in "carrier
>>>>> squelch"-mode ? I don't care whether it will be
>>>> decoded/encoded by the
>>>>> software or just passed through the repeater (0-300 Hz
>> passthrough).
>>>>> Currently passthrough of 0-300 Hz seems to be blocked by
>>>> the software.
>>>>> Thanks
>>>>> 73,
>>>>> Jann
>>>>> DG8NGN
>>>>> Jann Traschewski, Drosselstr.1, D-90513 Zirndorf, Germany
>>>>> Tel.: +49-911-696971, Mobile: +49-170-1045937, E-Mail:
jann@gmx.de
>>>>> Ham: DG8NGN / DB0VOX, http://www.qsl.net/dg8ngn, ICQ
UIN: 4130182
>>>>> _______________________________________________
>>>>> App_rpt-users mailing list
>>>>> App_rpt-users@qrvc.com
>>>>> http://qrvc.com/mailman/listinfo/app_rpt-users
