Creeping delay using usbradio on ASL3 3.10.4
OS Kernel : 6.18.39+rpt-rpi-v8
Asterisk : 22.10.1+asl3-3.10.4-1.deb13
ASL [app_rpt] : 3.10.4
Installed ASL packages :
Package Version
allmon3 1.9.1-1.deb13
asl3 3.18.2-2.deb13
asl3-appliance 2.2.0-1.deb13
asl3-appliance-pi 2.2.0-1.deb13
asl3-asterisk 2:22.10.1+asl3-3.10.4-1.deb13
asl3-asterisk-config 2:22.10.1+asl3-3.10.4-1.deb13
asl3-asterisk-modules 2:22.10.1+asl3-3.10.4-1.deb13
asl3-menu 1.18-1.deb13
asl3-tts 1.0.1-1.deb13
asl3-update-nodelist 2.1.0-1.deb13
asl-apt-repos 2.0-1.deb13
cockpit 337-1+deb13u1
cockpit-bridge 337-1+deb13u1
cockpit-networkmanager 337-1+deb13u1
cockpit-packagekit 337-1+deb13u1
cockpit-sosreport 337-1+deb13u1
cockpit-storaged 337-1+deb13u1
cockpit-system 337-1+deb13u1
cockpit-wifimanager 2.0-1.deb13
cockpit-ws 337-1+deb13u1
dahdi 1:3.1.0-2.1
dahdi-linux 1:3.4.0-11.asl.deb13
Using ASL3 3.10.4 beta, when Asterisk is freshly restarted, I noticed that the audio latency was longer than it used to be on older versions before the switch to portaudio.
I upgraded my node yesterday morning, then left it sitting in monitor mode on a node all day.
When I checked this morning, audio was about 7 seconds behind real time when comparing to another local node running 3.9.3, also using usbradio. PTT was firing when it should, but audio was extremely delayed, meaning a transmission would be seemingly cut off about 7 seconds too soon when PTT dropped.
If someone keyed during the window when my node wasn't transmitting, I'd get the remainder of the previous transmission, silence, then the start of the next one all in the same transmission.
This is on a simplex node.
Received audio seems to be OK. Only transmitted audio is affected.
It gradually became more and more delayed over time.
Restarting Asterisk (mostly) fixes it, but latency is still not quite what it was at it's best with 3.9.3 and older.
Interesting ... and it does look like we're slowly collecting transmit audio frames.
Q? you commented that you monitoring a single node all day.
  • was this a single connection over the entire time interval?
  • or were you connecting / disconnecting during the day?
  • and would other nodes have been connecting / disconnecting from your node during the day?
This node can't currently accept incoming connections. CGNAT with no compensation, currently. It is set up for that but is not currently active, so no one can connect or disconnect from my node. I literally just left it in monitor mode on a single mode all day and touched nothing. No commands, no transmitting to the node, just monitor mode and ran away, basically.
Sent from my zippo
On Aug 27, 2026, at 16:21, Allan N [email protected] wrote:
Someone replied to a topic you are Watching.
| WA3WCO ASL Community Admin
August 27 |
Thank you for your reply. Mike and I have been looking at the code, discussing possibilities ... and I'm starting to work up some code changes :slight_smile:
I too want to thank you for testing and letting us know. These types of bugs can be difficult to find/notice. We should have a fix soon.
We made a few changes that should help reduce the delay. The updated asl3-asterisk 22.10.1+asl3-3.10.5-1 packages are now in the "beta" stream.
