Someone asked for some help on the DVSwitch maillist for how to save (and make use of) recordings from their repeaters. I responded with a crude and unfinished solution to their issue and thought maybe some people here might be interested as it is based on the Allstar node at the core. So here is what I posted there…
I just did this again on one of my nodes so that I could remember how it was done easiest so here is a brief overview. If you want it done for you my rate is low. But I hold no secrets and if you have the time here I will explain what you need to do.
If you want to test the result I will leave this running on one of my servers for the next 12 hours. Test by connecting to DMR talkgroup 5446 or Allstar node 42177, transmit a message then refresh your browser with this url: http://108.61.224.90/AFP/index.php
Here is the overview of what is needed to " create your own hoseline":
Activate the archive directory in rpt.conf
recursively chmod that directory
install apache2
install php
install an HTML 5 audio player that dynamically creates a playlist from the directory contents
install rsync
install ffmpeg
Once everything is installed and configured simply write a simple bash script that does the following commands:
Rsync the archive log directory to the web server folder
Delete the original .WAV file from the archive directory
cd to the web server folder
ffmpeg and convert the .WAV files to .MP3
Delete the .WAV files
Loop this script.
Hope you get some use out of it and 73’s,
KG5EBI
