Courtesy Tones.....
Hi Mike,
I have a Simplex node, Hardware is Dell Latitude D600, connected to WLAN at 150mpbs. External ADSL is good, 15580mbps download speed. Running Top indicates:
top - 17:55:39 up 5 min, 2 users, load average: 0.14, 0.22, 0.12
Tasks: 71 total, 2 running, 69 sleeping, 0 stopped, 0 zombie
Cpu(s): 2.3%us, 0.3%sy, 0.0%ni, 97.3%id, 0.0%wa, 0.0%hi, 0.0%si, 0.0%st
Mem: 514596k total, 216224k used, 298372k free, 15360k buffers
Swap: 1020116k total, 0k used, 1020116k free, 139908k cached
   PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
  2466 root 15 0 39152 18m 5584 S 2.7 3.6 0:10.81 asterisk
  2809 root 15 0 2312 1008 812 R 0.3 0.2 0:00.01 top
Interface is modified CM108 USB device.
The problem I have, is when unconnected to any node. When connected, all is good - When station TXing on the link drops their TX, courtesy pip. All good.
The Issue is obviously something local, as whenever a signal is RXed locally, the box responds with a courtesy pip and a CWID and then drops carrier. But then proceeds to key up numerous times (anywhere between 6 & 14 at the last count), each key up giving a pip and then dropping carrier. If I go into rpt.conf and set unlinkedct=0, it will still key up multiple times - but no tone.
If I set duplex=0, the problem goes away (but I get no courtesy tones - but I still get "function complete" etc ok).
Something is looping somewhere.... it's just a case of trying to find it!
rpt.conf is pasted below!
Cheers,
James
[29681] ; Change this to your assigned node number
rxchannel=Radio/usb29681
duplex=1
erxgain=-6
etxgain=-6
;controlstates=controlstates
scheduler=schedule29681
morse=morse29681
macro=macro29681
functions=functions29681
phone_functions=functions29681
link_functions=functions29681
telemetry=telemetry
wait_times=wait-times
context = radio
callerid = "Repeater" <0000000000>
idrecording = |iG0FHM F
accountcode=RADIO
hangtime=50
althangtime=100
totime=170000
idtime=300000
;politeid=3000
linktolink=1
idtalkover=|iG0FHM F
unlinkedct=ct1
remotect=ct1
remotetx=ct1
linkunkeyct=ct1
nolocallinkct=1
;eannmode=1
;connpgm=yourconnectprogram
;discpgm=yourdisconnectprogram
;lnkactenable=0
;lnkacttime=1800
;lnkactmacro=*52
;lnkacttimerwarn=30seconds
;remote_inact_timeout=1800
;remote_timeout=3600
nounkeyct=0
holdofftelem=0
;beaconing=1
; *** Status Reporting ***
; Uncomment the either group following two statpost lines to report the status of your node to stats.allstarlink.org
; depending on whether you are running ACID or Limey Linux.
; ** For ACID ***
statpost_program=/usr/bin/wget,-q,--timeout=15,--tries=1,--output-document=/dev/null
statpost_url=http://stats.allstarlink.org/uhandler.php ; Status updates
; ** For Limey Linux **
;statpost_program=/bin/wget,-q,--timeout=15,--tries=1,--output-document=/dev/null
;statpost_url=http://stats.allstarlink.org/uhandler.php ; Status updates
; Morse code parameters, these are common to all repeaters.
[morse29681]
speed=30
frequency=800
amplitude=4096
idfrequency=800
idamplitude=1024
[schedule29681]
;dtmf_function = m h dom mon dow ; ala cron, star is implied
80=00 * * * *
80=15 * * * *
80=30 * * * *
80=45 * * * *
81=00 * * * *
[functions29681]
1=ilink,1
2=ilink,2
3=ilink,3
4=ilink,4
5=macro,1
70=ilink,5
71=ilink,6
72=ilink,7
73=ilink,15
74=ilink,16
75=ilink,8
80=status,1
81=status,2
6=autopatchup,noct=1,farenddisconnect=1,dialtime=20000 ; Autopatch up
0=autopatchdn ; Autopatch down
99=cop,43
980=status,3
;99=cop,6
; Place command macros here
[macro29681]
80=*80
81=*81
[telemetry]
;ct1=|t(350,0,100,2048)(500,0,100,2048)(660,0,100,2048)
ct1=|t(2175,0,50,8192)
;ct2=|t(660,880,150,2048)
ct2=|t(1633,0,50,3000)(0,0,80,0)(1209,0,50,3000)
ct3=|t(2175,0,150,4096)
ct4=|t(550,0,150,2048)
ct5=|t(660,0,150,2048)
ct6=|t(880,0,150,2048)
ct7=|t(660,440,150,2048)
ct8=|t(700,1100,150,2048)
;remotetx=|t(1633,0,50,3000)(0,0,80,0)(1209,0,50,3000)
remotetx=|t(2175,0,150,8192)
remotemon=|t(1209,0,50,2048)
cmdmode=|t(900,903,200,2048)
;functcomplete=|t(1000,0,100,2048)(0,0,100,0)(1000,0,100,2048)
functcomplete=|t(350,0,100,8192)(500,0,100,8192)(660,0,100,8192)
;functcomplete=|t(350,0,100,2048)(500,0,100,2048)(660,0,100,2048)
;functcomplete=|(2175,0,300,8192)
patchup=rpt/callproceeding
patchdown=rpt/callterminated
; A section for wait times can be defined for every repeater
[wait-times]
telemwait=2750
idwait=2750
unkeywait=500
calltermwait=2000
; This is where you define your nodes which cam be connected to.
[nodes]
; for your locak nodes, and private (off of allstar link) nodes here.
;29681 = radio@127.0.0.1/29681,NONE
; Memories for remote bases
[memory]
;00 = 146.580,100.0,m
;01 = 147.030,103.5,m+t
;02 = 147.240,103.5,m+t
;03 = 147.765,79.7,m-t
;04 = 146.460,100.0,m
;05 = 146.550,100.0,m
#includeifexists custom/rpt.conf
Since this is a half duplex radio, make sure you have duplex=1 in
rpt.conf and in usbradio.conf you have duplex = 0.
If usbradio has duplex = 1 then it thinks you have a full duplex
radio.
You need to tell usbradio it is half duplex.
By default app-Rpt defaults to full duplex settings in both usbradio
and in rpt conf.
Actually when duplex = X is not stated in then it is automatically
in full duplex mode in rpt conf.
Jon VA3RQ
On 6/24/2013 1:10 PM, James Hill wrote:
  Hi
Mike,
zombie
0.0%si, 0.0%st
buffers
cached
COMMAND
asterisk
tone.
tones - but I still get “function complete” etc ok).
find it!
  Cheers,
  James
  duplex=1
  erxgain=-6
  etxgain=-6
  morse=morse29681
  macro=macro29681
  telemetry=telemetry
  context =  radio
  accountcode=RADIO
  hangtime=50
  althangtime=100
  totime=170000
  idtime=300000
  ;politeid=3000
  linktolink=1
  unlinkedct=ct1
  remotect=ct1
  remotetx=ct1
  linkunkeyct=ct1
  nolocallinkct=1
  ;eannmode=1
  ;lnkactenable=0
  ;lnkacttime=1800
  ;lnkactmacro=*52
  nounkeyct=0
  holdofftelem=0
  ;beaconing=1
  ; ** For ACID ***
statpost_program=/usr/bin/wget,-q,–timeout=15,–tries=1,–output-document=/dev/null
  statpost_url= ; Status
updates
;statpost_program=/bin/wget,-q,–timeout=15,–tries=1,–output-document=/dev/null
;statpost_url= ; Status
updates
[morse29681]
speed=30
frequency=800
amplitude=4096
idfrequency=800
idamplitude=1024
[schedule29681]
80=00 * * * *
80=15 * * * *
80=30 * * * *
80=45 * * * *
81=00 * * * *
[functions29681]
1=ilink,1
2=ilink,2
3=ilink,3
4=ilink,4
5=macro,1
70=ilink,5
71=ilink,6
72=ilink,7
73=ilink,15
74=ilink,16
75=ilink,8
80=status,1
81=status,2
Autopatch up
99=cop,43
980=status,3
;99=cop,6
[macro29681]
80=*80
81=*81
[telemetry]
adjusted
[wait-times]
telemwait=2750
idwait=2750
unkeywait=500
calltermwait=2000
[nodes]
definition
here.
;29681 = ; Memories for remote bases
[memory]
Hi John,
usbradio.conf is duplex=0 - Always has been!
I’ve done a few more tests to rule out hardware (such as removing
the USB wlan dongle, rebooting & running on a cable) but still
no luck.
usbradio.conf contents are pasted below, for anyone that is
interested:
; Usbradio channel driver Configuration File
[general]
[usb29681]
hdwtype=0
rxboost=1
txboost=1
rxctcssrelax=1
;#txctcssdefault=100.0
;#rxctcssfreqs=100.0
;#txctcssfreqs=100.0
;rxctcssoverride=0
carrierfrom=vox
ctcssfrom=no
rxdemod=speaker
txprelim=no
txlimonly=no
txtoctype=notone
txmixa=voice
txmixb=no
invertptt=0
duplex=0
rxondelay=0
rxnoisefiltype=0
eeprom=0
#includeifexists custom/usbradio.conf
radio.
Try commenting out the link2link=1 in rpt conf.
then reload the RPT conf.
Jon
If you have a tail on the sinplex mode then you dont need that. Its
for connecting a node to a harware controller with full duplex and
no tails or ids.
On 6/24/2013 1:46 PM, James Hill wrote:
  Hi John,
no luck.
interested:
[general]
[usb29681]
hdwtype=0
rxboost=1
txboost=1
rxctcssrelax=1
;rxctcssoverride=0
carrierfrom=vox
ctcssfrom=no
rxdemod=speaker
txprelim=no
txlimonly=no
txtoctype=notone
txmixa=voice
txmixb=no
invertptt=0
duplex=0
rxondelay=0
rxnoisefiltype=0
eeprom=0
in rpt.conf and in usbradio.conf you have duplex = 0.
radio.
App_rpt-users@ohnosec.orghttp://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users
Hi All,
I've had a lengthy QSO with Mike, KB8JNM and followed the suggestions via this list.
The only thing that seems to stop the problem, is by setting rxondelay=120 in usbradio.conf. That in itself presents a problem, as the delay switching on the RX seems to be far more than 120ms, more like 4 seconds!
I could probably live with it, but John Q. Ham who happens to be passing through town and trying to use the node might have something different to say, and start badmouthing etc.
One thing I have noticed is this: I connected to my node via Echolink (with rxondelay=0), on my Android cell. I put a call out via my node. Whilst my node was going through it's pip pip cycle, I noticed that the green RX icon was up on the Echolink app, but no sound was coming through. The moment my node finally pipped it's last pip, the RX icon dropped, and the Echolink app gave it's roger beep.
So while it is going through it's tx pip cycle, it's also still saying it's TXing to the network.
If I set the all of the courtesy tones to 0 (apart from linkunkeyct) it looks for: app_rpt.c: telem_lookup:ctx failed on Zap/pseudo-1205069161
If I comment the lines out in rpt.conf, I just get bursts of carrier with no tones.
Mike wondered if it was due to the fact that I'm using vox instead of hard cor, and it's a timing issue. I'm not in a position to run hardware cor yet, as I'm not on the final radio - it's a Moto HT600 that I've temporarily pressed into service until I can find a good cheap commercial set that only has one or two channels. I'm not paying megabucks (approx $120 in the UK) for a 4ch GM-350 just to sit on a node!
Here is a short vid of what it's doing:
Until I can get it fixed, then I'm going to have to run with duplex=0 in rpt.conf :frowning:
Cheers all,
James G0FHM
Have you considered bringing out the discriminator from the HT-600 and using DSP?
Sent from my Android phone with K-9 Mail. Please excuse my brevity.
That is an option it looks like I'm going to have to explore - I've tried DSP on the speaker audio, and it just locks itself into RX mode - it will read incoming DTMF tones & will pass audio through to my cell which is connected via Echolink, but as it is, it won't snap out of RX mode!
I can make it TX by selecting F in radio-tune-menu no problem!
To get the disc. out of a HT600 is going to be a bit fiddly, but I'll give it a try tomorrow. It's either that, or set it to no tone mode for the time being, till I can source a suitable radio and do it properly.
James
Ok VOX is really unstable and not recommended if at all possible.
As it has been said "Friends dont let friends use VOX"
Hopefully once you get some hard connections to your radio then the problem will go away.
Jon RQ
On 6/24/2013 4:16 PM, James Hill wrote:
Hi All,
http://www.youtube.com/watch?v=VrWrEq3f6Ek
Cheers all,
James G0FHM
ohnosec.org
Right, I have broken out a COR line from my radio (+5v when a carrier is detected).
What do I do with it now?
I’ve tried going via a resistor and diode into the PP, pin 15 but the node is permanently locked into RX regardless of any connection. My usbradio.conf is pasted below:
[usb29681]
hdwtype=0
rxboost=1
txboost=1
rxctcssrelax=1
;rxctcssoverride=0
carrierfrom=pp
pp15=cor
ctcssfrom=no
rxdemod=speaker
txprelim=no
txlimonly=no
txtoctype=notone
txmixa=voice
txmixb=no
invertptt=0
duplex=0
rxondelay=0
rxnoisefiltype=0
eeprom=0
PP in BIOS is set to Bi Directional (assuming it makes a difference?). If I have to, I’ll go on to pin 47 (I think) of the CM108 chip, but I’d rather try the PP method first!
Cheers,
J
