Courtesy Tone when SIP connection unkeys
I have a private allstar node set up that allows a SIP connection.
No matter what I do I can’t seem to get allstar to TX a courtesy tone on the radio when the SIP connection unkeys. I feel like I’ve done this before but I’ve set every courtesy tone to a valid tone in rpt.conf and I get CT if the radio unkeys, but not if the SIP connection unkeys. Is this just not possible or am I being dumb?
Regards,
Mike Montalvo, KF7MBK
ARA Membership Chair
www.w7ara.org
Mike,
You probably need to look at other setting to be sure...
But first, be sure your current settings are not "out-of-range" and ignored.
& Type errors etc.
Some places to look...
unlinkedct=ct2
remotect=ct3
linkunkeyct=ct8
nolocallinkct=1 ; Use unlinkedct if only connected to a local node
Just a thought...
Be sure to fill us in if you find it.
...mike/kb8jnm
No matter what I do I can't seem to get allstar to TX a courtesy tone on
the radio when the SIP connection unkeys. I feel like I've done this
before but I've set every courtesy tone to a valid tone in rpt.conf and I
Regards,
www.w7ara.org
http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users and scroll down to the
bottom of the page. Enter your email address and press the "Unsubscribe or edit
options button"
problem.
My experience is that SIP connections use the "linkunkeyct" so be sure you have it pointing to a courtesy tone that is valid and has some value defined.
N5ZUA
On 12/15/2015 8:58 PM, mike@midnighteng.com wrote:
Mike,
& Type errors etc.
unlinkedct=ct2
remotect=ct3
linkunkeyct=ct8
Just a thought...
...mike/kb8jnm
Regards,
www.w7ara.org
options button"
problem.
I set ALL the CTs to the same known good CT, and after the change there was a change on the radio side, but not the SIP side.
Set duplex to 1
telemdefault=1
holdofftelem=1, also tried 0
nolocallinkct=0 also tried 1
I’ll try again, but I may just dump this V1 BBB install and go to a RP2 install…
On Tue, Dec 15, 2015 at 7:58 PM, mike@midnighteng.com wrote:
Mike,
You probably need to look at other setting to be sure…
But first, be sure your current settings are not “out-of-range” and ignored.
& Type errors etc.
Some places to look…
unlinkedct=ct2
remotect=ct3
linkunkeyct=ct8
Just a thought…
…mike/kb8jnm
Regards,
www.w7ara.org
options button"
problem.
Regards,
www.w7ara.org
I can only say that I am stumped and out of ideas outside of re-compiling your
install. Perhaps a look at your sip settings and context.
I think it is 'possible' for the format of the audio of the CT to be out of range
of the "ALLOWED" formats for/in the sip settings. Something to check. I would not
think that should affect rpt output but who knows.
...mike/kb8jnm
Set duplex to 1
telemdefault=1
I'll try again, but I may just dump this V1 BBB install and go to a RP2
install..
Regards,
www.w7ara.org
On Tue, Dec 15, 2015 at 7:58 PM, <mike@midnighteng.com> wrote:
Mike,
ignored.
& Type errors etc.
unlinkedct=ct2
remotect=ct3
linkunkeyct=ct8
Just a thought...
...mike/kb8jnm
this
> Regards,
> www.w7ara.org
> App_rpt-users mailing list
down to the
or edit
> options button"
confirmation. If
detailing the
> problem.
options button"
problem.
