Router crashed and we reinstalled node changed local IP address. Now get the unable to log into Asterisk Manager message. I have forwarded all the appropriate ports to the new IP Address
Sounds like your router crashed so you reinstalled your node… is that right? In any case, reinstalling your node will require editing manager.conf to configure the password, etc… did you do that?
Yes, I did edit the manager.conf file and I can log into Supermon. Supermon cannot log into the asterisk manager.
Manager.conf must match the settings in allmon.inc.php in order for Allmon to login in to Asterisk. I don’t run Supermon but I assume the same applies. HamVoIP folks get on here occasionally, maybe they will confirm and/or help.
Thanks, yes the settings are the same in both files
You did remember to verify the bindaddress as well as the port number
used in manager.conf?
Making sure they match your allmon.ini file for each node you want to
log into?
Also Depending on your Port Forward and how NAT works for your system…
If your Supermon/Allmon is running on a different server on a LAN than
the node you are trying to log into you may need to add/edit each IP to
the opposite node’s [Node] section.
All things to check out.
Larry - N7FM
On 6/18/20 12:14 PM, Doug Bornstein via AllStarLink Discussion Groups wrote:
[K6JV] K6JV https://community.allstarlink.org/u/k6jv
June 18Thanks, yes the settings are the same in both files
Visit Topic
https://community.allstarlink.org/t/could-not-log-into-asterisk-manager/17158/5
or reply to this email to respond.
In Reply To[wd6awp] wd6awp https://community.allstarlink.org/u/wd6awp ASL Admin
June 18Manager.conf must match the settings in allmon.inc.php in order for
confirm and/or help.Previous Replies[wd6awp] wd6awp https://community.allstarlink.org/u/wd6awp ASL Admin
confirm and/or help.[K6JV] K6JV https://community.allstarlink.org/u/k6jv
June 18Yes, I did edit the manager.conf file and I can log into Supermon.
Supermon cannot log into the asterisk manager.[wd6awp] wd6awp https://community.allstarlink.org/u/wd6awp ASL Admin
June 18Sounds like your router crashed so you reinstalled your node… is that
manager.conf to configure the password, etc… did you do that?[K6JV] K6JV https://community.allstarlink.org/u/k6jv
June 18Router crashed and we reinstalled node changed local IP address. Now get
Visit Topic
or reply to this email to respond.You are receiving this because you enabled mailing list mode.
To unsubscribe from these emails, click here
https://community.allstarlink.org/email/unsubscribe/833c4e24a7423d51c0ce2981f6786b1f1aef64c5fbc1f5f32d1ec2797b55f3b5.
Thanks Larry, is the bindadress the 127.0.0.0? The port number shows as 5038. I am trying to run this from the same IP as the node.
Doug,
In that case it should work if all that matches.
You have created the .htaccess login for the web browser Yes?
If not you won’t be able to login
Larry - N7FM
June 18Thanks Larry, is the bindadress the 127.0.0.0? The port number shows as
Visit Topic
https://community.allstarlink.org/t/could-not-log-into-asterisk-manager/17158/7
Previous Replies[larry] larry https://community.allstarlink.org/u/larry
June 18You did remember to verify the bindaddress as well as the port number
used in manager.conf?Making sure they match your allmon.ini file for each node you want to
log into?Also Depending on your Port Forward and how NAT works for your system…
the opposite node’s [Node] section.All things to check out.
Larry - N7FM
··· (click for more details)
https://community.allstarlink.org/t/could-not-log-into-asterisk-manager/17158/6
Visit Topic
https://community.allstarlink.org/email/unsubscribe/146b637ab8bed6658c6ab653143585b553c560610c39a963734b8aa9f097a6aa.
