N4IRS
June 30, 2024, 3:53pm
1
Let me start by saying WELL DONE! This is a giant step forward for AllStarLink.
I have ASL3 install on a SHARI. All is working well. I setup DVSwitch Mobile as a IAX client.
Everything is working but I ran into a minor issue, see below:
No big deal. I have not started to debug yet.
wd6awp
June 30, 2024, 5:06pm
2
Thank you Steve. The team worked their asses off for a couple of years to get there. I’m very proud of them.
Not sure what IAX client you are referring to. Is this via usrp? Let us know what you find out.
N8EI
June 30, 2024, 5:11pm
3
Indeed. I’ve had DVSwitch Mobile users running on the pre-beta and beta for months now without issue. Please let us know what you’re seeing.
N4IRS
June 30, 2024, 5:20pm
4
Look at the connected node.N4IRSP Maybe should be N4IRS P
N4IRS
June 30, 2024, 5:24pm
5
Rx-Frame Retry[ No] – OSeqno: 000 ISeqno: 000 Type: IAX Subclass: NEW
Timestamp: 00000ms SCall: 11114 DCall: 00000 192.168.190.151:4569
VERSION : 2
CALLED NUMBER : 2153
CALLING NUMBER :
CALLING NAME : N4IRS
USERNAME : N4IRS
FORMAT : 108
CODEC_PREFS : (slin|ulaw|adpcm|alaw)
CALLTOKEN : 51 bytes
Tx-Frame Retry[-01] – OSeqno: 000 ISeqno: 001 Type: IAX Subclass: ACK
Timestamp: 00003ms SCall: 03919 DCall: 11114 192.168.190.151:4569
Tx-Frame Retry[000] – OSeqno: 000 ISeqno: 001 Type: IAX Subclass: AUTHREQ
Timestamp: 00006ms SCall: 03919 DCall: 11114 192.168.190.151:4569
AUTHMETHODS : 2
CHALLENGE : \x37\x35\x36\x32\x34\x38\x39\x37\x32
USERNAME : N4IRS
Tx-Frame Retry[001] – OSeqno: 000 ISeqno: 001 Type: IAX Subclass: AUTHREQ
AUTHMETHODS : 2
USERNAME : N4IRS
Rx-Frame Retry[ No] – OSeqno: 001 ISeqno: 001 Type: IAX Subclass: AUTHREP
Timestamp: 02107ms SCall: 11114 DCall: 03919 192.168.190.151:4569
USERNAME : N4IRS
MD5 RESULT : 1494cd046c82998b6d7b51bafe941e19
REFRESH : 60
Tx-Frame Retry[-01] – OSeqno: 001 ISeqno: 002 Type: IAX Subclass: ACK
Timestamp: 02107ms SCall: 03919 DCall: 11114 192.168.190.151:4569
Tx-Frame Retry[000] – OSeqno: 001 ISeqno: 002 Type: IAX Subclass: ACCEPT
Timestamp: 02112ms SCall: 03919 DCall: 11114 192.168.190.151:4569
FORMAT : 4
FORMAT2 : ulaw
Rx-Frame Retry[ No] – OSeqno: 002 ISeqno: 001 Type: IAX Subclass: AUTHREP
Timestamp: 02108ms SCall: 11114 DCall: 03919 192.168.190.151:4569
USERNAME : N4IRS
REFRESH : 60
N4IRS
July 23, 2024, 2:28pm
7
To answer my own question. As I said in my first post, I setup DVSwitch Mobile as a IAX client.
I used the [iaxclient] stanza in iax.conf, all I changed was the password. The picture in my first post shows N4IRSP is connected.
Turns out the P is added in the [iax-client] stanza in extensions.conf by:
same => n,rpt(${NODE}|P|${CALLSIGN}-P )
I understand the reason for adding -P to a connection (though I removed it) I think the stat page should reflect the actual connection (add the dash, or strip the dash P alltogether)
Steve N4IRS
system
Closed
July 26, 2024, 3:21pm
8
