COR signal getting confused
Resending since my initial post has been pending moderation for 2 days now and got no reply from the list owner email.
I have modified an HT to bring out the receive LED signal and use it
as the COR input to a DMK URI. It is a digital signal as viewed on a
scope (i.e. very short slope in the transitions) This seems like it
would work well and it does on strong signals. But on marginal signals
where the LED may blink on and off quickly (like during picket
fencing), it seems to confuse the URI (or the software) were it will
start off good, but then a quick dropout of the COR signal will cause
the software to no longer detect carrier, even though the signal on
the COR input has been restored. Even if the input is solid high (or
low in my case, I’m using usbinvert) it will not detect a carrier
until there is another dropout of adequate time to “reset” it.
I’ve tried putting a simple RC on the input but it didn’t really help
much. Seems the URI (or software) needs a significant minimum time
between transitions to properly detect them, long enough that it would
delay the carrier detection too much without a circuit more complex
than an RC (i.e. something that would allow instant keyup, but delay
the key down.)
Linked is a scope image.
https://lh5.googleusercontent.com/-CsJ9autUTAE/VCWK-uNJJpI/AAAAAAAAPSM/VsVvbPVvuEA/s800/20140923_184107.jpg
Carrier was detected until this signal
dropout event. Ch A is my RC filtered signal sent to the URI, Ch B is
the signal out of the radio. Carrier was not detected after the 5th
dropout even though the signal remained low.
Anyone ever experience this and/or have ideas on how to fix it?
Thanks.
Mike
KF7MBK
low in my case, I'm using usbinvert) it will not detect a carrier
until there is another dropout of adequate time to "reset" it.
I've tried putting a simple RC on the input but it didn't really help
the key down.)
Thanks.
Mike
KF7MBK
To: kf7mbk@w7ara.net
Subject: RE: [App_rpt-users] Fwd: COR signal getting confused
Date: Fri, 26 Sep 2014 12:46:14 -0400
That is very strange. Have you changed any of the default timing values? Are you using simplex/duplex? Courtesy tone? Timing values could effect that.
I use simplex with courtesy tone (duplex=1 in rpt.conf) on several nodes and I have never seen that problem. I have one user who has a signal like you describe. He walks in a park with a handheld and he is often in and out.
Also I assume you are not using any rxdelay?
73 Doug
WA3DSP
Date: Fri, 26 Sep 2014 08:50:51 -0700
To: app_rpt-users@ohnosec.org
Subject: [App_rpt-users] Fwd: COR signal getting confused
The URI wants to see a signal that goes hi to low or open collector
to ground. It also has a diode on the input to block incoming
voltage. So if your COR line sources a voltage then removes it but
doesn’t go all the way to ground when it goes low, then the URI will
not see a transition.
So perhaps you can put a resistor to the base of a NPN transistor
and connect the collector to the URI I/P. Change the carrier from to
“USB” in usbradio.conf and you should be good to go.
use it
viewed on a
like it
signals
it will
will cause
signal on
high (or
carrier
really help
time
it would
complex
delay
      the key down.)
Ch B is
the 5th
it?
      Thanks.
      Mike
      KF7MBK
Doug,
First: thanks for the excellent writeup on getting allstar running on the BBB. I used it to get up and running very quickly and is the setup I am having this issue with.
I am running duplex =1 as well. I have not changed any timing values, (I’m essentially running the as-installed setup from the install image on your site) but I will take a look at them and see if I can make some changes for the better.
Thanks!
-Mike
73 Doug
WA3DSP
the key down.)
Thanks.
Mike
KF7MBK
Mike,
Before you change any timing make sure as Jon pointed out that your COS signal is going hard high and low on signal and non-signal. You might need a pullup. The URI is kind of weak in that regard. It should be TTL levels <.5 volt low and >2.5 volt high and preferably rail to rail.
73 Doug
WA3DSP
Date: Fri, 26 Sep 2014 09:56:21 -0700
Subject: Re: [App_rpt-users] Fwd: COR signal getting confused
To: doug@crompton.com
CC: app_rpt-users@ohnosec.org
Doug,
Thanks!
-Mike
73 Doug
WA3DSP
the key down.)
Thanks.
Mike
KF7MBK
The scope image in the OP shows there doesn’t appear to be a problem with pulling hi or low, The transitions (without the RC) are very clean and go all the way to ground… It seems like the URI is doing edge detection instead of level detection, and it’s just missing fast edges. Wasn’t sure if this was something that could be tweaked in software or if I’ll have to put some external debounce logic on the line.
On Fri, Sep 26, 2014 at 10:07 AM, Doug Crompton doug@crompton.com wrote:
Mike,
73 Doug
WA3DSP
Doug,
Thanks!
-Mike
73 Doug
WA3DSP
the key down.)
Thanks.
Mike
KF7MBK
Mike,
Are you using PL or noise squelch or both? Like I said I have not seen this problem and I am using basically stock timing. Every time the PL or squelch goes untrue for a certain (short) duration you should hear a courtesy tone. Perhpas you should try duplex=0 just to see if there is an issue with TX recovery. Do you have another radio you can try?
73 Doug
WA3DSP
Date: Fri, 26 Sep 2014 10:18:19 -0700
Mike,
73 Doug
WA3DSP
Doug,
Thanks!
-Mike
73 Doug
WA3DSP
the key down.)
Thanks.
Mike
KF7MBK
OK, so I did some more testing.
I have routed the signal out of the radio to an NPN and switched from usbinvert to usb as suggested. This made little difference, but in this configuration I could make the RC work a little better bridging the dropouts. But still would end up not detecting carrier after a quick dropout even though the COR signal into the dongle was high.
Duplex = 0 seems to eliminate the problem. Is there a setting to tell it how long to wait after COR dropped to start transmitting the courtesy tone? (though I suppose that would defeat the purpose of the duplex=1 setting) Note that I have the PTT disconnected for testing, so all I see is the red LED come on as soon as the COR out of the radio drops.
Actually as I’m typing this and playing with it, I just noticed it appears if the COR is restored ANY time the PTT is active for the courtesy tone, it will ignore the COR line until it’s dropped and brought back up AFTER the PTT is done. This behavior seems VERY repeatable, even with a cleanly restored COR signal, So it may have nothing to do with quick dropouts and everything to do with the courtesy tone…
Are there any settings that control this?
The LED on the radio (and hence my COR input) is controlled by noise squelch opening.
On Fri, Sep 26, 2014 at 3:05 PM, Doug Crompton doug@crompton.com wrote:
Mike,
73 Doug
WA3DSP
Mike,
73 Doug
WA3DSP
Doug,
Thanks!
-Mike
73 Doug
WA3DSP
the key down.)
Thanks.
Mike
KF7MBK
Mike,
You can try the changing the courtesy time wait then set back to duplex=1
The wait-times section
This section allows the wait times for voice responses and other audio telemetry events to be adjusted. All
wait times are in milliseconds.
telemwait
sets the time before sending the general audio telemetry responses used
in the application which are not specifically defined below
idwait sets the time to wait before sending ID audio telemetry
unkeywait
sets the amount of time to wait before sending the courtesy tone. This can be used to ensure breaking stations can get their turn
calltermwait sets the amount of time between an autopatch disconnect and the audio telemetry message indicating the call has been terminated
The unkeywait is the one to mess with. It is 400ms on the BBB by default. Make it longer like 1000 so it spans the dropout period you are seeing. Experiment with times.
If that doesn’t work I really think you should try a different radio. My thoughts are that it is some kind of recovery issue with TX.
73 Doug
WA3DSP
Date: Fri, 26 Sep 2014 18:59:26 -0700
Mike,
73 Doug
WA3DSP
Mike,
73 Doug
WA3DSP
Doug,
Thanks!
-Mike
73 Doug
WA3DSP
the key down.)
Thanks.
Mike
KF7MBK
Doug, this behavior happens even if I manually toggle the COR independent of the radio and audio so unless I’m not understanding, I can’t see this being the radio.
I tried changing unkeywait to 1000 but made no difference other than extending the time the PTT is active for the courtesy tone, and thus extending the window in which the COR line going high will be ignored. Seems that anything that extends the time that the PTT is active for the courtesy tone also extends the time that the COR is ignored.
Just to make sure I’m not doing anything stupid or have an unconventional setuo,. my test setup is:
HT → DMK URI → BBB (node 1998) → ethernet → Allstar on a VM (node 1620) → IAX → Zioper soft phone on laptop
HT has audio in/out connected to the URI. PTT from the URI is not connected to the HT while testing. Signal from receive LED on the HT goes to COR URI input.
I have the HT tuned to the weather frequency and I’m making/breaking the antenna connection to simulate picket fencing and I’m monitoring the audio received by the URI/BBB on the softphone.
Bottom line is if the COR line drops, the courtesy pause and tone is instantly triggered, triggering the URI PTT. This works. But, if while the PTT is active, the COR line goes high again, the audio through the URI is not routed through until the COR line goes low* and high again after the PTT/courtesy tone is done transmitting.
  • when going low after getting ignored going high, no courtesy tone is triggered.
Would it be useful/appropriate change carrierfrom to “no” and instead set ctcssfrom = usb and switch the radio output to the ctcss input on the URI and see if the problem still exists?
Thanks for all the help!
-Mike
On Fri, Sep 26, 2014 at 8:37 PM, Doug Crompton doug@crompton.com wrote:
Mike,
telemwait
unkeywait
73 Doug
WA3DSP
Mike,
73 Doug
WA3DSP
Mike,
73 Doug
WA3DSP
Doug,
Thanks!
-Mike
73 Doug
WA3DSP
the key down.)
Thanks.
Mike
KF7MBK
What HT brand/model are you using, just out of curiosity?
On 9/26/2014 11:37 PM, Doug Crompton wrote:
Mike,
This section allows the wait times for voice responses and other audio telemetry events to be adjusted. All wait times are in milliseconds.
*/telemwait/* sets the time before sending the general audio telemetry responses used in the application which are not specifically defined below
*/idwait/* sets the time to wait before sending ID audio telemetry
*/unkeywait/* sets the amount of time to wait before sending the courtesy tone. This can be used to ensure breaking stations can get their turn
*/calltermwait/* sets the amount of time between an autopatch disconnect and the audio telemetry message indicating the call has been terminated
If that doesn't work I really think you should try a different radio. My thoughts are that it is some kind of recovery issue with TX.
*73 Doug
WA3DSP
WA3DSP Amateur Radio Resources*
Actually as I'm typing this and playing with it, I just noticed it appears if the COR is restored ANY time the PTT is active for the courtesy tone, it will ignore the COR line until it's dropped and brought back up AFTER the PTT is done. This behavior seems VERY repeatable, even with a cleanly restored COR signal, So it may have nothing to do with quick dropouts and everything to do with the courtesy tone..
On Fri, Sep 26, 2014 at 3:05 PM, Doug Crompton <doug@crompton.com > <mailto:doug@crompton.com>> wrote:
    Mike,
    *73 Doug
    WA3DSP
    To: doug@crompton.com <mailto:doug@crompton.com>
    CC: app_rpt-users@ohnosec.org <mailto:app_rpt-users@ohnosec.org>
    The scope image in the OP shows there doesn't appear to be a
    are very clean and go all the way to ground.. It seems like the
    URI is doing edge detection instead of level detection, and it's
    just missing fast edges. Wasn't sure if this was something that
    could be tweaked in software or if I'll have to put some external
    On Fri, Sep 26, 2014 at 10:07 AM, Doug Crompton <doug@crompton.com > <mailto:doug@crompton.com>> wrote:
        Mike,
        *73 Doug
        WA3DSP
        Doug,
        values, (I'm essentially running the as-installed setup from
        Thanks!
        -Mike
        On Fri, Sep 26, 2014 at 9:49 AM, Doug Crompton > <doug@crompton.com <mailto:doug@crompton.com>> wrote:
            To: kf7mbk@w7ara.net <mailto:kf7mbk@w7ara.net>
            *73 Doug
            WA3DSP
            owner email.
            and use it
            viewed on a
            seems like it
            marginal signals
            were it will
            will cause
            signal on
            solid high (or
            carrier
            really help
            minimum time
            that it would
            more complex
            but delay
            the key down.)
            URI, Ch B is
            after the 5th
            fix it?
            Thanks.
            Mike
            KF7MBK
            App_rpt-users mailing list App_rpt-users@ohnosec.org
            <mailto:App_rpt-users@ohnosec.org>
            button" You do not need a password to unsubscribe, you can
            do it via email confirmation. If you have trouble
            unsubscribing, please send a message to the list detailing
            the problem.
Puxing 777
On Fri, Sep 26, 2014 at 9:27 PM, (KP4TR)Ramon Gonzalez kp4tr.ramon@gmail.com wrote:
out of curiosity?
Mike,
to duplex=1
milliseconds.
    ***telemwait*** sets the time before sending
unkeywait sets the amount of time to
with TX.
    **73 Doug
      WA3DSP
      [http://www.crompton.com/hamradio](http://www.crompton.com/hamradio)**
high.
radio drops.
tone…
wrote:
Mike,
you can try?
                  **73 Doug
                    WA3DSP
getting confused
wrote:
Mike,
                                  **73 Doug
                                    WA3DSP
-0700
Doug,
up and running very
as well. I have not
for the better.
Thanks!
-Mike
                                                Subject: RE:
COR signal getting
confused
                                                Date: Fri, 26 Sep
2014 12:46:14 -0400
the default
timing values?
Are you using
simplex/duplex?
Courtesy tone?
Timing values
could effect
that.
                                                    I use simplex
with courtesy
tone (duplex=1
in rpt.conf) on
several nodes
and I have never
seen that
problem. I have
one user who has
a signal like
you describe. He
walks in a park
with a handheld
and he is often
in and out.
                                                    Also I assume
you are not
using any
rxdelay?
                                                  **                                                          73
Doug
WA3DSP
http://www.crompton.com/hamradio**
                                                    Date: Fri, 26
Sep 2014
08:50:51 -0700
                                                    Subject:
[App_rpt-users]
Fwd: COR signal
getting confused
                                                      Resending
since my
initial post
has been
pending
moderation for
2 days now and
got no reply
from the list
owner email.
                                                      I have
modified an HT
to bring out
the receive
LED signal and
use it
                                                      as the COR
input to a DMK
URI. It is a
digital signal
as viewed on a
                                                      scope (i.e.
very short
slope in the
transitions)
This seems
like it
                                                      would work
well and it
does on strong
signals. But
on marginal
signals
                                                      where the LED
may blink on
and off
quickly (like
during picket
                                                      fencing), it
seems to
confuse the
URI (or the
software) were
it will
                                                      start off
good, but then
a quick
dropout of the
COR signal
will cause
                                                      the software
to no longer
detect
carrier, even
though the
signal on
                                                      the COR input
has been
restored.
Even if the
input is solid
high (or
                                                      low in my
case, I’m
using
usbinvert) it
will not
detect a
carrier
                                                      until there is
another
dropout of
adequate time
to “reset” it.
                                                      I've tried
putting a
simple RC on
the input but
it didn’t
really help
                                                      much.  Seems
the URI (or
software)
needs a
significant
minimum time
                                                      between
transitions to
properly
detect them,
long enough
that it would
                                                      delay the
carrier
detection too
much without a
circuit more
complex
                                                      than an RC
(i.e.
something that
would allow
instant keyup,
but delay
                                                      the key down.)
                                                      Linked is a
scope image.
                                                      Carrier
was detected
until this
signal
                                                      dropout
event. Ch A
is my RC
filtered
signal sent to
the URI, Ch B
is
                                                      the signal out
of the radio.
Carrier was
not detected
after the 5th
                                                      dropout even
though the
signal
remained low.
                                                      Anyone ever
experience
this and/or
have ideas on
how to fix it?
                                                      Thanks.
                                                      Mike
                                                      KF7MBK
App_rpt-users
mailing list
To unsubscribe
from this list
and scroll
down to the
bottom of the
page. Enter
your email
address and
press the
“Unsubscribe
or edit
options
button”
You do not
need a
password to
unsubscribe,
you can do it
via email
confirmation.
If you have
trouble
unsubscribing,
please send a
message to the
list detailing
the problem.
Try this in usbradio.conf (this is not recognized in simpleusb):
rxondelay=25 ; This will instruct the usbradio driver to ignore the COR line
                         ; for a specified number of 20mSec intervals following the release of PTT.
Mike,
*73 Doug
WA3DSP
    Mike,
    *73 Doug
    WA3DSP
        Mike,
        *73 Doug
        WA3DSP
        Doug,
        Thanks!
        -Mike
            *73 Doug
            WA3DSP
            owner email.
            and use it
            viewed on a
            seems like it
            marginal signals
            were it will
            will cause
            signal on
            solid high (or
            carrier
            really help
            minimum time
            that it would
            more complex
            but delay
            the key down.)
            URI, Ch B is
            after the 5th
            fix it?
            Thanks.
            Mike
            KF7MBK
            the problem.
The ctcss and carrier from are just bits so technically you could use either one and it would work the same. You do need to set the one you are not using to none. We always use carrierfrom even though it is ctcss that is driving it.
I tried what you are doing here. I listened to myself iaxrpt from a distant node. Then I key the local PTT on my handheld into my local node. I immediately unkey and then keyed again before I heard the courtesy tone and it worked fine. Tried it several times.
Why don’t you eliminate the 1620 node in the test and iaxrpt directly to 1998 to see what happens there.
This is acting like what you would see with an rxdelay setting but it should be 0 by default unless you somehow got that into your config. Specifically say rxdelay=0 in the 1998 rpt.conf context to be sure.
73 Doug
WA3DSP
Date: Fri, 26 Sep 2014 21:15:03 -0700
-Mike
Mike,
telemwait
unkeywait
73 Doug
WA3DSP
Mike,
73 Doug
WA3DSP
Mike,
73 Doug
WA3DSP
Doug,
Thanks!
-Mike
73 Doug
WA3DSP
the key down.)
Thanks.
Mike
KF7MBK
That command does work in simpleusb also but I think it is the opposite that is the problem. It is not responding. Worth a try I suppose.
73 Doug
WA3DSP
Date: Sat, 27 Sep 2014 00:32:19 -0400
To: doug@crompton.com; kf7mbk@w7ara.net
Mike,
to duplex=1
milliseconds.
with TX.
    **73 Doug
      WA3DSP
high.
radio drops.
tone…
          On Fri, Sep 26, 2014 at 3:05 PM, > Doug Crompton <doug@crompton.com> >               wrote:
Mike,
you can try?
                  **73 Doug
                    WA3DSP
getting confused
                          On Fri, Sep 26, 2014 at 10:07 AM, Doug > > Crompton <doug@crompton.com> > >                               wrote:
Mike,
                                  **73 Doug
                                    WA3DSP
-0700
Doug,
up and running very
as well. I have not
for the better.
Thanks!
-Mike
                                          On Fri, Sep 26, 2014 at > > > 9:49 AM, Doug Crompton <doug@crompton.com> > > >                                               wrote:
                                                Subject: RE:
COR signal getting
confused
                                                Date: Fri, 26 Sep
2014 12:46:14 -0400
the default
timing values?
Are you using
simplex/duplex?
Courtesy tone?
Timing values
could effect
that.
                                                    I use simplex
with courtesy
tone (duplex=1
in rpt.conf) on
several nodes
and I have never
seen that
problem. I have
one user who has
a signal like
you describe. He
walks in a park
with a handheld
and he is often
in and out.
                                                    Also I assume
you are not
using any
rxdelay?
                                                  **                                                          73
Doug
WA3DSP
                                                    Date: Fri, 26
Sep 2014
08:50:51 -0700
                                                    Subject:
[App_rpt-users]
Fwd: COR signal
getting confused
                                                      Resending
since my
initial post
has been
pending
moderation for
2 days now and
got no reply
from the list
owner email.
                                                      I have
modified an HT
to bring out
the receive
LED signal and
use it
                                                      as the COR
input to a DMK
URI. It is a
digital signal
as viewed on a
                                                      scope (i.e.
very short
slope in the
transitions)
This seems
like it
                                                      would work
well and it
does on strong
signals. But
on marginal
signals
                                                      where the LED
may blink on
and off
quickly (like
during picket
                                                      fencing), it
seems to
confuse the
URI (or the
software) were
it will
                                                      start off
good, but then
a quick
dropout of the
COR signal
will cause
                                                      the software
to no longer
detect
carrier, even
though the
signal on
                                                      the COR input
has been
restored.
Even if the
input is solid
high (or
                                                      low in my
case, I’m
using
usbinvert) it
will not
detect a
carrier
                                                      until there is
another
dropout of
adequate time
to “reset” it.
                                                      I've tried
putting a
simple RC on
the input but
it didn’t
really help
                                                      much.  Seems
the URI (or
software)
needs a
significant
minimum time
                                                      between
transitions to
properly
detect them,
long enough
that it would
                                                      delay the
carrier
detection too
much without a
circuit more
complex
                                                      than an RC
(i.e.
something that
would allow
instant keyup,
but delay
                                                      the key down.)
                                                      Linked is a
scope image.
                                                      Carrier
was detected
until this
signal
                                                      dropout
event. Ch A
is my RC
filtered
signal sent to
the URI, Ch B
is
                                                      the signal out
of the radio.
Carrier was
not detected
after the 5th
                                                      dropout even
though the
signal
remained low.
                                                      Anyone ever
experience
this and/or
have ideas on
how to fix it?
                                                      Thanks.
                                                      Mike
                                                      KF7MBK
App_rpt-users
mailing list
To unsubscribe
from this list
and scroll
down to the
bottom of the
page. Enter
your email
address and
press the
“Unsubscribe
or edit
options
button”
You do not
need a
password to
unsubscribe,
you can do it
via email
confirmation.
If you have
trouble
unsubscribing,
please send a
message to the
list detailing
the problem.
rxdelay delays qualifying the COS signal until the number of milliseconds after PTT release. This would be true for the courtesy tone also because any TX could cause a false COS trigger if you had that problem.
Maybe you just need to disable the courtesy tone.
73 Doug
WA3DSP
Date: Sat, 27 Sep 2014 00:49:15 -0400
73 Doug
WA3DSP
Mike,
to duplex=1
milliseconds.
with TX.
    **73 Doug
      WA3DSP
high.
radio drops.
tone…
Mike,
you can try?
                  **73 Doug
                    WA3DSP
getting confused
Mike,
                                  **73 Doug
                                    WA3DSP
-0700
Doug,
up and running very
as well. I have not
for the better.
Thanks!
-Mike
                                                Subject: RE:
COR signal getting
confused
                                                Date: Fri, 26 Sep
2014 12:46:14 -0400
the default
timing values?
Are you using
simplex/duplex?
Courtesy tone?
Timing values
could effect
that.
                                                    I use simplex
with courtesy
tone (duplex=1
in rpt.conf) on
several nodes
and I have never
seen that
problem. I have
one user who has
a signal like
you describe. He
walks in a park
with a handheld
and he is often
in and out.
                                                    Also I assume
you are not
using any
rxdelay?
                                                  **                                                          73
Doug
WA3DSP
                                                    Date: Fri, 26
Sep 2014
08:50:51 -0700
                                                    Subject:
[App_rpt-users]
Fwd: COR signal
getting confused
                                                      Resending
since my
initial post
has been
pending
moderation for
2 days now and
got no reply
from the list
owner email.
                                                      I have
modified an HT
to bring out
the receive
LED signal and
use it
                                                      as the COR
input to a DMK
URI. It is a
digital signal
as viewed on a
                                                      scope (i.e.
very short
slope in the
transitions)
This seems
like it
                                                      would work
well and it
does on strong
signals. But
on marginal
signals
                                                      where the LED
may blink on
and off
quickly (like
during picket
                                                      fencing), it
seems to
confuse the
URI (or the
software) were
it will
                                                      start off
good, but then
a quick
dropout of the
COR signal
will cause
                                                      the software
to no longer
detect
carrier, even
though the
signal on
                                                      the COR input
has been
restored.
Even if the
input is solid
high (or
                                                      low in my
case, I’m
using
usbinvert) it
will not
detect a
carrier
                                                      until there is
another
dropout of
adequate time
to “reset” it.
                                                      I've tried
putting a
simple RC on
the input but
it didn’t
really help
                                                      much.  Seems
the URI (or
software)
needs a
significant
minimum time
                                                      between
transitions to
properly
detect them,
long enough
that it would
                                                      delay the
carrier
detection too
much without a
circuit more
complex
                                                      than an RC
(i.e.
something that
would allow
instant keyup,
but delay
                                                      the key down.)
                                                      Linked is a
scope image.
                                                      Carrier
was detected
until this
signal
                                                      dropout
event. Ch A
is my RC
filtered
signal sent to
the URI, Ch B
is
                                                      the signal out
of the radio.
Carrier was
not detected
after the 5th
                                                      dropout even
though the
signal
remained low.
                                                      Anyone ever
experience
this and/or
have ideas on
how to fix it?
                                                      Thanks.
                                                      Mike
                                                      KF7MBK
App_rpt-users
mailing list
To unsubscribe
from this list
and scroll
down to the
bottom of the
page. Enter
your email
address and
press the
“Unsubscribe
or edit
options
button”
You do not
need a
password to
unsubscribe,
you can do it
via email
confirmation.
If you have
trouble
unsubscribing,
please send a
message to the
list detailing
the problem.
/div
I’m starting to think its the URI.
First, I got rid of all the components (transistor and RC) because they made little difference and don’t want the added complexity. I went back to usbinvert.
I brought the radio and URI to the 1620 node on the VM (basically a stock install of ACID) and connected Zoiper directly to the node. This left the BBB and its configuration completely out of the loop and I still got the same behavior.
Next I reconnected the URI and radio to the BBB and connected directly to it via Zioper (I didn’t do this before because I was having trouble connecting Zoiper to the BBB, but I got that figured out) and it’s still the same behavior.
And just to eliminate the radio, I disconnected it completely, connected the COR input to a pullup, and grounded it by hand. When I ground the COR line (usbinvert), I can hear slight background noise through Zoiper and when I unground it, the courtesy tone is triggered (URI PTT active as well) and then the background noise goes away when the CT is done. But if I ground the COR line while the courtesy tone is playing, it ignores the COR and does not pass audio to zioper until I cycle the COR line again.
And finally I tried using the CTCSS input, same exact behavior.
I know there is a URI test program from DMK, but I didn’t really see a way to simply read out the status of the inputs, just automated tests requiring a loopback.
-Mike
73 Doug
WA3DSP
-Mike
Mike,
telemwait
unkeywait
73 Doug
WA3DSP
Mike,
73 Doug
WA3DSP
Mike,
73 Doug
WA3DSP
Doug,
Thanks!
-Mike
73 Doug
WA3DSP
the key down.)
Thanks.
Mike
KF7MBK
Ok In a bid to understand what it is you think is wrong let me clarify from what you are saying below.
Your node is set up for duplex=1 (half duplex with courtesy beep and tail) right?
And the problem you are seeing is the node will not receive a signal when it is transmitting the courtesy beep or tail - right?
If the above is correct, then this configuration cannot receive a signal while it is transmitting. This is normal for this configuration.
If your radio is portable or mobile radio, then your radio can only receive or transmit but not both simultaneously. So in duplex =1 mode the URI assumes your receiver is active if the node isnt transmitting. So the node ignores all receiver activity while its transmitting. Once the tail is gone then it will listen to thereceiver cor line.
For some reason from you explanation below you are expecting the node to receive in full duplex. Unless the radio you have connected is capable of full duplex, this wont work. If the radio connected to the URI is a pair of radios or a duplexed base station and if you set the duplex setting to duplex=2 in rpt conf and duplex =1 in usbradio then it will receive while its transmitting.
Hope I understand this right and this helps.
Jon VA3RQ
On 9/27/2014 11:47 AM, Mike M wrote:
I'm starting to think its the URI.
First, I got rid of all the components (transistor and RC) because they made little difference and don't want the added complexity. I went back to usbinvert.
Next I reconnected the URI and radio to the BBB and connected directly to it via Zioper (I didn't do this before because I was having trouble connecting Zoiper to the BBB, but I got that figured out) and it's still the same behavior.
I know there is a URI test program from DMK, but I didn't really see a way to simply read out the status of the inputs, just automated tests requiring a loopback.
-Mike
sage to the list detailing the problem.
I should further clarify the "duplex=1 mode" settings.
This is the mode when in rpt.conf has duplex set to 1 and usbradio has duplex=0.
This config is a half duplex mode but gives a courtesy beep and tail after RX activity.
The duplex=1 mode in rpt.conf tells the node it is in half duplex mode but sends a courtesy beep and a tail after it receives a signal from the node receiver.
The duplex=0 in usbradio tells the URI hardware that your radio is only half duplex and cannot transmit while receiving.
The setup for half duplex nodes is kinda nice as it tells the user that they are making the sinplex node.
A setting of duplex =0 in rpt conf and duplex =0 in usbradio is the same as above with no courtesy tone and no tail.
It works just as well as above but there is no local feedback to let you know if you are hitting the simplex node or not.
Jon VA3RQ
Jon VA3RQ
-Mike
Correct, in both conf files.
While true, this isn't the actual problem.
I drew a diagram which will hopefully be worth 1000 words.
Though I just realized, I may have the order of the silence and the
tone backwards. Regardless, it is not the important issue.
-Mike
Cc:
tail) right?
configuration.
cor line.
Jon VA3RQ
Date: Sat, 27 Sep 2014 12:11:19 -0400
usbinvert.
same behavior.
behavior.
a loopback.
-Mike
driving it.
Why don't you eliminate the 1620 node in the test and iaxrpt directly to
73 Doug
WA3DSP
________________________________
of the radio and audio so unless I'm not understanding, I can't see this
being the radio.
Just to make sure I'm not doing anything stupid or have an unconventional
HT -> DMK URI -> BBB (node 1998) -> ethernet -> Allstar on a VM (node
1620) -> IAX -> Zioper soft phone on laptop
to COR URI input.
I have the HT tuned to the weather frequency and I'm making/breaking the
antenna connection to simulate picket fencing and I'm monitoring the audio
* when going low after getting ignored going high, no courtesy tone is
triggered.
Would it be useful/appropriate change carrierfrom to "no" and instead set
-Mike
On Fri, Sep 26, 2014 at 8:37 PM, Doug Crompton <doug@crompton.com> wrote:
Mike,
telemwait sets the time before sending the general audio telemetry
unkeywait sets the amount of time to wait before sending the courtesy
73 Doug
WA3DSP
squelch opening.
On Fri, Sep 26, 2014 at 3:05 PM, Doug Crompton <doug@crompton.com> wrote:
Mike,
73 Doug
WA3DSP
The scope image in the OP shows there doesn't appear to be a problem with
all the way to ground.. It seems like the URI is doing edge detection
instead of level detection, and it's just missing fast edges. Wasn't sure
if this was something that could be tweaked in software or if I'll have to
On Fri, Sep 26, 2014 at 10:07 AM, Doug Crompton <doug@crompton.com> wrote:
Mike,
73 Doug
WA3DSP
Doug,
(I'm essentially running the as-installed setup from the install image on
for the better.
Thanks!
-Mike
that.
73 Doug
WA3DSP
the key down.)
Thanks.
Mike
KF7MBK
_______________________________________________ App_rpt-users mailing list
ohnosec.org To unsubscribe
or edit options button" You do not need a password to unsubscribe, you can
do it via email confirmation. If you have trouble unsubscribing, please send
a message to the list detailing the problem.
