connection
Hi
I cannot receive connections to my node 29310 i have the router portforwarded to 4569 udp.
thanks for any help.
Scott va3xy
Is it possible that your service provider may be blocking 4569? Mine did and I had to request for them to open it.
73,
Eric
4Z5UG / WA6IGR
Allstar Node: 28422
4Z5UG@guth.us
Israel Direct: 077-950-9451
USA Direct: +1-720-377-3840
From: app_rpt-users-bounces@ohnosec.org [mailto:app_rpt-users-bounces@ohnosec.org] On Behalf Of Scott M
Sent: Monday, February 04, 2013 5:35 PM
To: app_rpt-users@ohnosec.org
Subject: [App_rpt-users] connection
Hi
Scott va3xy
What type of router are you using?
Keith va3yc
Sent from my iPhone
On Feb 4, 2013, at 11:35 AM, Scott M va3xy@yahoo.ca wrote:
Hi
Scott va3xy
I don't mean to insult your intelligence, but the best of us make simple
errors.
Check your portforward. Make sure port 4569 is the source and 4569 is
the port going to your allstarlink node.
Some routers will allow to you specify a source IP or network, make sure
it's blank or 0.0.0.0 to allow all incoming connections to that port.
If you are not using your DMZ, and all else fails, set the allstarlink
node computer on the DMZ. Not a good idea, but do that temporarily to
see if that help solve some issues.
~Benjamin, KB9LFZ
Allstar node 28569
On Mon, 2013-02-04 at 07:35 -0800, Scott M wrote:
Hi
Scott va3xy
ohnosec.org
Hi
Thanks for the ideas, i removed the router and still no joy. My service provider has it blocked and will not open it. Looks like i will have to use a proxy server.
Thanks again
Scott VA3XY
Benjamin L. Naber Benjamin@kb9lfz.com
To: Scott M va3xy@yahoo.ca
Cc:app_rpt-users@ohnosec.orgapp_rpt-users@ohnosec.org
Sent: Monday, February 4, 2013 5:08:23 PM
Subject: Re: [Bulk] [App_rpt-users] connection
I don’t mean to insult your intelligence, but the best of us make
simple
errors.
it’s blank or 0.0.0.0 to allow all incoming connections to that port.
~Benjamin, KB9LFZ
Allstar node 28569
Hi
Scott va3xy
Which isp?
iThing: Big thumbs & little keys. Please excuse typo, spelling and grammar errors • Thought of the Day – "With all this manure, there must be a pony in here somewhere.”
On 2013-02-04, at 17:33, Scott M va3xy@yahoo.ca wrote:
Hi
Thanks again
Scott VA3XY
simple
errors.
~Benjamin, KB9LFZ
Allstar node 28569
Hi
Scott va3xy
if I am not mistaken, you can send an email to the contact email address
on allstarlink.org and ask them to use a different port number for you.
I'm curious as to why they would block that port? Suppose they don't
want folks to make their own phone systems and circumventing theirs?
~Benjamin, KB9LFZ
On Mon, 2013-02-04 at 14:33 -0800, Scott M wrote:
Hi
Thanks again
Scott VA3XY
               Benjamin L. Naber <Benjamin@kb9lfz.com>
To: Scott M <va3xy@yahoo.ca>
Cc: "app_rpt-users@ohnosec.org" <app_rpt-users@ohnosec.org>
simple
errors.
sure
~Benjamin, KB9LFZ
Allstar node 28569
> Hi
> Scott va3xy
> App_rpt-users mailing list
> ohnosec.org
Dont need to send an email to Jim. He just have to change the UDP port innthe network setting on the webportal for his server and all will be fine!
Envoyé de mon iPad
~Benjamin, KB9LFZ
Hi
Thanks again
Scott VA3XY
simple
errors.
sure
~Benjamin, KB9LFZ
Allstar node 28569
Hi
Scott va3xy
ohnosec.org
ohnosec.org
You can change the port on the allstar portal and then change it in the appropriate files in /etc/asterisk, also change it in your router. Reboot and you should be good to go…
Corey N3FE
Sent: Monday, February 04, 2013 5:33 PM
To: Benjamin L. Naber
Cc: app_rpt-users@ohnosec.org
Subject: Re: [App_rpt-users] [Bulk] connection
Hi
Thanks again
Scott VA3XY
I don’t mean to insult your intelligence, but the best of us make simple
errors.
~Benjamin, KB9LFZ
Allstar node 28569
Hi
Scott va3xy
This message was scanned and is believed to be clean.
Click here to report this message as spam.
bell mobilty, i think a proxy server is my only hope. but im open to suggestions.
thanks
Scott
Cc: Benjamin L. Naber Benjamin@kb9lfz.com; “app_rpt-users@ohnosec.orgapp_rpt-users@ohnosec.org
Sent: Monday, February 4, 2013 6:49:43 PM
Which isp?
Hi
Thanks again
Scott VA3XY
simple
errors.
~Benjamin, KB9LFZ
Allstar node 28569
Hi
Scott va3xy
Ok if you are on a wireless connection like HSPA/3G/4G or “Rocket
Stick/ Hub” and on Bell Mobility, then you do not have a public IP.
So you will be able to connect out but nodes cannot connect in. The
IP that is reported to the network does not forward any ports.
If you switch to Rogers and get the Rocket hub, you can pay for a
Public IP option, then you will be able to forward the correct
ports. Bell does not have the option of a Public IP on that service.
You can try the VPN or proxy. Dont know if that will work. Good
luck.
Jon VA3RQ
thanks
Scott
S. Scott Scott
M Benjamin L. Naber ;
Which isp?
              On 2013-02-04, at 17:33, Scott M <va3xy@yahoo.ca                  >
wrote:
Hi
Thanks again
Scott VA3XY
                      Benjamin
To:
Cc:
"app_rpt-users@ohnosec.org "
<app_rpt-users@ohnosec.org >
Sent:
Subject:
                      errors.
                      ~Benjamin, KB9LFZ
                      Allstar node 28569
wrote:
                      > Hi
                      > Scott va3xy
                      > [http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users](http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users)
8f27e956@gmail.com
To:va3xy@yahoo.ca
Cc:Benjamin@kb9lfz.com"app_rpt-users@ohnosec.org"app_rpt-users@ohnosec.org
Sent:
Subject:
App_rpt-users@ohnosec.orghttp://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users
If you build a pptp VPN you can around the bell limitations. A proxy will not be required.
Keith
Va3yc
Sent from my iPhone
thanks
Scott
Which isp?
Hi
Thanks again
Scott VA3XY
simple
errors.
~Benjamin, KB9LFZ
Allstar node 28569
Hi
Scott va3xy
