You will need to check your rpt.conf file for your assigned command for these as mine may be different than yours.
918=cop,11 ; User linking functions enable
919=cop,12 ; User linking functions disable
Both nodes are on same server 579050 and 579051 579050 connects one way 579051 connects both ways works fine what could be the problem.
579050=radio@156.57.193.89:4568/579050,156.57.193.89
579051=radio@156.57.193.89:4569/579051,156.57.193.89
Obviously, they are not on the same server, but on the same external public IP.
This would be a question for that owner to reveal his data if he wanted to know.
But I might suspect he already does not care.
He does not have correct port forwarding in his router to the correct NAT IP would be my guess.
But how would I know unless someone would present that data.
But the skinny is, you have no issue so I can’t help you.
Can’t really ask what someone else’s problem is when they are not seeking answers and presenting data to find out.
Hey i have no dout he cares he has put alot of hrs in this and has been a ham for along time has alot invested in this hobby we thought one one of us would put it out there and ask questions .
I presented the most likely. Don’t know any more.Can’t read minds or system/router config’s.
If he wants help, I suppose he will ask for it and present data to find the issue.
It’s the only way I know of to do it, but I’m open for suggestions.
Am looking for info i can connect to another node but i am the only node that can connect to that paritcular node ?
