I have a node behind my NAT router (50026):
192.168.1.250
port 4569 allstar
port 5198-5200 echolink
port 5201 supermon
The above all works!!! The echolink and allstar can accept connections from outside
I have a second PI running a different node(49267):
192.168.1.249
port 4568 allstar
port 5202 supermon
This node will not connect to the first node…always a “Connection Failed”
I have updated the iax.conf file
[general]
bindport=4568
bindaddr=0.0.0.0
I have updated the the port at the server end to 4568
You have to configure each node for the other's node number in the [nodes] stanza.
This is due to the IP for your nodes in extnodes being the public IP. This
means node 49267 will try to connect to the public IP for 50026. You need to
set this up so it knows the direct private IP connection.
Technically some routers can be configured to permit this, but most don't.
73's
192.168.1.250
port 4569 allstar
port 5201 supermon
outside
“Laws that forbid the carrying of arms…disarm only those who are neither inclined nor determined to commit crimes. Such laws make things worse for the assaulted and better for the assailants; they serve rather to encourage than prevent homicides, for an unarmed man may be attacked with greater confidence than an armed one.”
If you don’t do this they can’t find each other behind the firewall. One warning, my one node is in a ammo box so it goes in the car with me…when I do that I need to comment out that line in the homes nodes or it won;t look for the portable node’s public address.
Well you have a good understanding of whats going on.
Thanks, David
I had switched a node from being portable. Put a brand new load on the SD card and configured everything and is Showing Registered from the CLI>
I also set [nodes] in each node server,
in the rpt.conf and changed the appropriate port for each of the nodes in iax.conf under [general]
As I am trying to setup a two server behind a firewall I had configured both systems one 4569 (28523/28525) the other 4568 (42022) the 42022 in the CLI> iax2 show registry still shows 44.98.xx.xx:4569 state: Registered.
I have both port forwarding the ports to there individual IP’s on the router.
What am I doing wrong?
Marty
Sorry forgot to also say I have different port number Server 1 :4569, Server 2 :4568 that has been done before I sent in my issue. I’ll keep looking. Maybe I fat fingered case or miss a letter or number, something. Thank you.
Nate,
I have checked my account for both servers they reflect the correct port for the node/server used. I did notice my IP is changed from my public IP from the one Echolink reports back. I am logged into the system, I see my eEcholink node listed but when anyone tries to connect it times out. Now I am using a AT&T Hotspot Allstar is working great! I even used Qtel for Echolink and it is working. So at this point I’ll get hold of the Echolink floks and see what they say.
TNX, 73,
Marty
I will still try and peruse this. Thank you for your help but was in the process as the time getting my home ready to sell and move. I moved out in Nov and now ready to move back in to a new home hopefully in May 3. I’ve been too distracted with that and other personal thing going on but starting back to the hobby!
I have changed the IAX port and will also check my rpt_config file. Thank you!
Marty
