Connect SIP Phone to allstarlink box
Hi all,
I would like to connect 2-3 SIP Phones to the allstarlink box. Is it possible to call to each other AND to the repeater ?
Is there anyone you can help me doing that ? or are there some howto`s ?
I think I must write the “User/Clients/Phones” t0 the sip.conf and need some dialplans for calls from sip to sip and from sip to allstarlink-repeater
Tnx for the help
73…
Torben Klimt
Eicherstrasse 58
85123 Karlskron-Grillheim
Telefon: 08453-34 45 040
Fax: 08453 - 4085296
Mobil: 0151-178 74499
torben@klimt-online.com
Here is another good reference
http://kd3su.us/allStar/acid-sysadmin.pdf
On Thu, Dec 19, 2013 at 5:00 PM, mike@midnighteng.com wrote:
The answer to the one part is -Yes- you can connect to your sip/iax to app_rpt extension on the system.
Nothing extra is needed but the sip definition in the system and a compatible sip phone/software on your network.
Not to be taken the wrong way,
I would think many of us could help you through that but,
We have no way of knowing how much you know about the supporting structure, being asterisk pbx.
So I would say that you should look-up the support you need from asterisk online manuals on setting up a phone sip extension. Get the manual for asterisk at asterisk.org and you might learn about the many capabilities of asterisk why you are at it.
When you have a particular problem doing that, ask that particular question. Many are glad to help.
Here is my sip extention for my ipad (with sip software)
–sip.conf
[6010] ;iPad
deny=0.0.0.0/0.0.0.0
username=6010
secret=yoursecretpassword
dtmfmode=rfc2833
canreinvite=no
context=radio-control
host=dynamic
trustrpid=yes
sendrpid=no
type=friend
nat=no
port=5060
qualify=yes
qualifyfreq=60
transport=udp
encryption=no
callgroup=
pickupgroup=
dial=SIP/6010
That should get you started but get the asterisk manual. Many answers are in there.
…mike/kb8jnm
-------- Original Message --------
Subject: [App_rpt-users] Connect SIP Phone to allstarlink box
From: “torben@klimt-online.comtorben@klimt-online.com
Date: Thu, December 19, 2013 5:04 pm
To: “app_rpt-users@ohnosec.orgapp_rpt-users@ohnosec.org
Hi all,
Tnx for the help
73…
Torben Klimt
Eicherstrasse 58
hi all,
i have problems with echolink on my node. after running allstar more then xx days it is not possible to connect out but it is possible to connect the node. ithink there is a file / database with the information nodenumber/ip/call and
that file is not up to date. after restarting allstarlink all is working well
any ideas ?
tnx 73 de torben dh6mbt
hi all,
i know the post is a little bit older but the last days i had some time for testing and playing with my allstarnode.
@mike: tnx a lot for your instructions on the page http://themidnightengineer.com/category/ham-amateur-radio/app_rpt/config-set-up/
a call from SIP to repeater runs fine now but i have 2 questions
a, you write in your instruction "exten => 29283,n,Rpt,29283|P ; make connection – the P is for phone control mode"
are there any other possibilitys for P ? is it possible to connect like the allstarlink telefon portal with VOX PTT ? instead of *99 and # ??
b, how can i call from the repeater to the SIP(i take the 6010 like you of course...)
tnx a lot and have a nice weekend
73.... tom dh6mbt
________________________________
Von: app_rpt-users-bounces@ohnosec.org [app_rpt-users-bounces@ohnosec.org] im Auftrag von mike@midnighteng.com [mike@midnighteng.com]
Gesendet: Freitag, 20. Dezember 2013 00:00
An: app_rpt-users@ohnosec.org
Betreff: Re: [App_rpt-users] Connect SIP Phone to allstarlink box
So I would say that you should look-up the support you need from asterisk online manuals on setting up a phone sip extension. Get the manual for asterisk at asterisk.org<http://asterisk.org/> and you might learn about the many capabilities of asterisk why you are at it.
--sip.conf
[6010] ;iPad
username=6010
dtmfmode=rfc2833
canreinvite=no
host=dynamic
trustrpid=yes
sendrpid=no
type=friend
nat=no
port=5060
qualify=yes
qualifyfreq=60
transport=udp
encryption=no
callgroup=
pickupgroup=
dial=SIP/6010
...mike/kb8jnm
From: "torben@klimt-online.com<mailto:torben@klimt-online.com>" <torben@klimt-online.com<mailto:torben@klimt-online.com>>
To: "app_rpt-users@ohnosec.org<mailto:app_rpt-users@ohnosec.org>" <app_rpt-users@ohnosec.org<mailto:app_rpt-users@ohnosec.org>>
Hi all,
Tnx for the help
73…
Torben Klimt
Eicherstrasse 58
torben@klimt-online.com<https://exchange.df.eu/owa/redir.aspx?C=a04ffef3e8f44fe88175e5e5127907d7&URL=mailto%3Atorben%40klimt-online.com>
App_rpt-users@ohnosec.org<mailto:App_rpt-users@ohnosec.org>
Page 34
Phone Control Mode Command Example in extensions.conf
Dumb exten=>1234,nRpt,1234|D
Normal exten=>1234,n,Rpt,1234|P
Phone exten=>1234,n,Rpt,1234|P
Simple exten=>1234,n,Rpt,1234|S
VOX exten=>1234,n,Rpt,1234|Pv
Hope that helps...
I read thru page 34. I am a novice at this. I would like to buy a few SIP phones that I could program to point to my repeater. I do not need to get and outside POTS line. This would be for me and another ham yo be able to pick up the phone and dial the extension to monitor and control the repeater. It would be nice to be able to dial our extentions directly to talk off air.
The part of monitor/control the repeater seems to be explained well enough I just need to understand what is written down. The part of be able to call each others extension is still foggy to me.
This may seem silly to you guys but it’s quite a project for me.
When I started down that path, I picked up a copy of “Asterisk: The Definitive Guide” at the book store.
An online verision is here : http://www.asteriskdocs.org/en/3rd_Edition/asterisk-book-html-chunk/index.html
Take a look at chapter 5.
This version addresses Asterisk 1.8, but the basics are the same.
