Configuration
Good morning! I continue to make progress standing up my server (42316 / ACID Distro). The next item is Repeater Modes. Think in terms of "normal operations" or "emergency operations". I want user controls to switch between Repeater Modes. This has generated the following questions.
1) The "5" lead in character points to the MACRO Stanza. I get that. Can I have a second lead in character like "A" that goes to a different macro stanza?
2) In rpt.conf each command seems to go to a single action. Can you have multiple step commands (other than macros)? Are there APP_RPT variables that are Readable / Changeable with accompanying flow control syntax? Are there User assignable variables?
3) In extensions.conf you can chain commands, do some if-then-goto-label. Is there a linkage that allows a command from rpt.conf to link to a dialed extension number in extensions.conf?
The sledding is a little tough, but so far the software seems reliable.
...STeve - KF5VH
