Command to Disable/Enable ID
I have a link to a remote repeater using the input frequency.
We finally figured out how to execute a command when the last link disconnects but not when 1 link is still connected while the other disconnects.
In the connect and disconnect script files, we have the DTMF dialing.
**Is there a command I can use to completely disable the ID without disabling any other telemetry or changing anything else so I can put that in the script files? **
The node ONLY needs to ID when it is transmitting, and the ONLY time it transmits is when it is connected to a link.
you might say “hey, what if you are only connected for 8 mins, not 10 and it does not ID” , well I will have it ID on disconnect.
Thanks, this is the last problem we have to fix, and if not, our only other choice is to let the ID loop play every 10 mins.
Skyler Fennell
amsatnet.info
KDØWHB
[email protected]
hi skyler
look at this site he has a lot of very useful script for allstar. take a good look at the " astflip " script.
it will do what you need. it will allow you to change to completely different copy of rpt.conf.
you set a rpt.normal file and a rpt.fipped file then what the script will do is replace your rpt.conf with
  the normal file or the flipped file upon demand via a dtmf command.
it use this script to do exactly what you are trying to do twice a week to feed a repeater system a skywarn net.
And when i do that the script change the running config of allstar for the net and turns off all courtesy tones
and other stuff.
ken n1dot
you might say "hey, what if you are only connected for 8 mins, not 10 and it does not ID" , well I will have it ID on disconnect.
Skyler Fennell
amsatnet.info <http://amsatnet.info>
KD�WHB
[email protected] <mailto:[email protected]>
[email protected]
hi skyler
oops i forgot to include the link to the site.
ken n1dot
On 7/28/2014 3:08 PM, Kenneth Grimard wrote:
hi skyler
and other stuff.
ken n1dot
Skyler Fennell
KD�WHB
[email protected]
To unsubscribe from this list please visithttp://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users and scroll down to the bottom of the page. Enter your email address and press the "Unsubscribe or edit options button"
Will asterisk have to restart to change this because I can not have the links disconnect when the change is taken place because the change will take place on link connect.
hi skyler
command.
  and other stuff.
  ken n1dot
frequency.
DTMF dialing.
** Is there a command I can use to completely disable the
disconnect.
mins.
Skyler Fennell
amsatnet.info
KDØWHB
[email protected]
[email protected]http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-usershttp://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users
yes it will have to restart that may be a problem.
some things can not be changed until you ether reload you rpt config or restart asterisk.
ken n1dot
On Jul 28, 2014, at 9:08 AM, Kenneth Grimard <[email protected] > <mailto:[email protected]>> wrote:
hi skyler
and other stuff.
ken n1dot
Skyler Fennell
KDØWHB
[email protected]
What is COP 17 and 18?
It says that it can do this : does that mean that it can do this
  • 17 - User functions (time, id, etc) enable
  • 18 - User functions (time, id, etc) disable
would that solve my problem? I would use COP 17 to enable and COP 18 to disable
Skyler KDØWHB
Thanks, that’s what I wanted!
I will test it out, hope, crossing my fingers that no node disconnects.
Skyler
there is no dtmf command for that ulese
you create one.
  it requires that you do asterisk -rx " rpt reload " from the
asterisk cli or an external script
  from the cli you use rpt reload.
  ken n1dot
  On 7/28/2014 5:30 PM, Skyler Fennell wrote:
    What's the command for rpt reload? Sorry I'm new to all this
still
    Skyler
    On Jul 28, 2014, at 11:19 AM, Kenneth Grimard <[email protected]        >
wrote:
no it should not.
        ken
        On 7/28/2014 4:59 PM, Skyler Fennell wrote:
          Will an RPT.conf reload (not an asterisk reload)
disconnect the node?
          Would there be any way without the nodes all
disconnecting to solve this problem?
          On Jul 28, 2014, at 10:44 AM, Kenneth Grimard <[email protected]
wrote:
            no those only disable or enable user function codes
only. they will not disable the id’s at all.
ken n1dot
              On 7/28/2014 4:40 PM,
that it can do this
  • 17 - User functions (time, id ,
    etc) enable
  • 18 - User functions (time, id ,
    etc) disable
Skyler KDØWHB
