Greetings:
I have just been made aware of a problem with the official Allstarlink.org parrot server at node 2002.
If a HamVoIP node calls 2002, no audio passes. This is because HamVoIP, for some silly reason, prefers G726-AAL2, and the version of the parrot code running on 2002 doesn’t know how to handle that. KC1FSZ’s current parrot fixes this problem by both supporting the G726-AAL2 codec and handling codec priority better. The end-result is that HamVoIP nodes (and there are still a lot of them out there) will connect using the hosting node’s preference, I.E. it should almost always use G711U.
I also just noticed that KC1FSZ’s node on 61057 is not disconnecting automatically at the end of the session as it should.
