WA1NVC
January 1, 2026, 8:37pm
1
At first I thought this was a Trixie problem but when I put the latest updates on a Bookworm node it appeared there too.
From the Cockpit: Accounts and Services both re-paint the screen rapidly preventing use.
My guess is this happened sometime in December.
These are all using the pi appliance on RPi4
Roger
WA1NVC
N8EI
January 2, 2026, 3:12am
2
I cannot recreate this behavior. What browser are you using?
WA1NVC
January 2, 2026, 1:46pm
3
I have been using Firefox forever.
I just tried Chrome(totally unsecure) and it does not occur.
Now to see what has changed in Firefox....
WA1NVC
January 2, 2026, 2:06pm
4
I found that Firefox had turned on a lot of features in the last update. I turned off things like picture in picture, show touchscreen, etc that I did not have on before and the issue seems to have gone away.
Warning to Firefox users: check your settings.
Roger
WA1NVC
N8EI
January 2, 2026, 3:47pm
5
Interesting. Yes, Firefox does cycle on that. Looks like this is a known issue with Cockpit:
opened 05:06PM - 22 Dec 25 UTC
bug
jira
### Explain what happens
1. Login to any Cockpit (Redhat) portal using Firefox
… 2. Go to Services page
3. Perpetual reload appearing to be js-triggered
**Actual results:**
The Services page is stuck in a reloading loop that never ends.
Other portal's sections are fine.
**Expected results:**
The Services page should load once and be usable.
Firefox v143 does not seem affected. Versions in-between have not been tested.
### Version of Cockpit
351
### Where is the problem in Cockpit?
Services page
### Server operating system
Fedora
### Server operating system version
42
### What browsers are you using?
Firefox
LibreWolf (same problem)
### System log
```shell
Edit: As suggested by @sacc-leo , a workaround would be to hit CTRL+R during the refreshing madness and it should stop.
This will persist until the tab is closed. The problem comes back with new tabs.
N8EI
January 2, 2026, 4:03pm
6
Looks like it's an issue with uBlock Origin. I have that in Firefox. I disabled it for my node's host and it works fine.
WA1NVC
January 2, 2026, 8:06pm
7
I have no idea what "uBlock Origin" is or how to disable it. If its an add on, I do not have it installed.
The only fix I found was to click the Reload Current Page and it stops the constant re-load.
Roger
