I’m running DIAL on a R-Pi2 into a modified USB fob for connection to my repeater.
Everything seems to load and be configured fine, but I can’t get the fob PTT to trip. I believe the PTT FET is driven from the red LED on the fob (pin13) and I can’t get a new unmodded fob to cycle the red LED either.
Simpleusb-tune-menu “f” test of PTT and audio shows no LED/PTT activity, but tone is OK.
Audio courtesy tones and hang time and receive audio passes the in/out of the fob during COR, just NO keying.
Now I did install DIAL on the R-Pi2 without CM108 attached if that was important.
Everything
Simpleusb-tune-menu "f"
Audio
Now
Ideas
where the config is unright?
73,
Duane
KA1LM #42996
[](http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users)[http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users](http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users)
To unsubscribe from this list please visit [](http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users)[http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users](http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users)
and scroll down to the bottom of the page. Enter your email
address and press the “Unsubscribe or edit options button”
email confirmation. If you have trouble unsubscribing, please
send a message to the list detailing the problem.
See enclosed photo…you will need to cut a
trace that angles over to the switch on the side of the board with the Red LED,
and drill a hole as shown (1/16"), then solder a piece of wire wrap wire
from the trace leading to the angle trace (from LED resistor R10) and connect
it via the hole to pin 13 on the CM-108. I’ve done it several times. I kind of
like the red LED when I’m troubleshooting the Pi or the BBB rpt_app setup.
I’m
repeater.
Everything
Simpleusb-tune-menu
OK.
Audio
Now I
