Cloud Server - 2 Nodes - Each with it's OWN EL Credentials
As WB6OZD points out, you will need another WAN IP address for the second EchoLink node. Add a [el1] stanza in echolink.conf to configure the second EchoLink node and associated Allstar node if different from the first. The “ipaddr =” line in EchoLink.conf will specify the IP address to bind to for each EchoLink node stanza.
For outgoing connections to EchoLInk, you might reference https://community.allstarlink.org/t/multiple-echolink-nodes/8938 Allstar nodes will default to using the [el0] stanza EchoLink node in echolink.conf for outgoing EchoLink connections. If you have multiple Allstar nodes or want to specifiy a different EchoLink node stanza, try adding “eloutbound=el1” to rpt.conf with the appropriate EchoLink stanza value in the desired Allstar node stanza.
David McAnally
WD5M
WX5FWD SKYWARN Team
