I have 2 Vultr Cloud Nodes with several repeater nodes connected to each Cloud node and the 2 cloud nodes at times connected to each other. I would like to send a voice announcement from one or the other hubs to all of the connected nodes - I am having trouble seeing how to make this work. TIA, steve nu5d
DISREGARD !!! Syntax - replace localplay with playback - solved…
steve
Declare a command (non-conflicting) and use playback & location
6501=Playback,/var/lib/asterisk/sounds/abandon-all-hope.ulaw ; test
This could as well be something you recorded. but stick to available codec formats.
One you have the command, test it manually and at that point, you could run it within a macro and scheduler.
TU Mike - I had rpt playback instead of playback… 73 steve
Only works if duplex isn’t set to 0 in rpt.conf (bug)
