Has anyone else have or solved node connection issues to a Allstar Cloud Hub? Best I can tell its an DNS issue. Example, node is connected to Cloud Hub from home internet. Node then is taken mobile and can not connect to Cloud Hub, but can connect to other non cloud Allstar nodes. Cloud Hub gets booted and issue is cleared. I also seen just booting a node can cause it not to be able to connect back to the Cloud Hub too.
Transition ip nodes, fixed to mobile. Right now I have node 50141 that can not connect to hub, but it connects to 48005. If I boot hub, they will be able to connect. I did find the white/black list makes it worse, so I removed it. On Allstarlink.org if you say yes to remote base it occurs more often on that node.
Then simply ran Allstar configuration and setup node. This way it does not relying on my home internet. Its for a 24 site linked repeater system that NWS uses.
Guess I must not be using the app correctly. I have responded to all questions. Either my explanations are not clear or your not seeing them. Here is what I have previously posted.
Thanks David
" Transition ip nodes, fixed to mobile. Right now I have node 50141 that can not connect to hub, but it connects to 48005. If I boot hub, they will be able to connect. I did find the white/black list makes it worse, so I removed it. On Allstarlink.org if you say yes to remote base it occurs more often on that node.
David KG5RDF
NCTC.INFO "
Yes, I have the cloud hub 47996 Ubuntu Server 16.04 LTS. Issue is inbound and outbound. Some of the nodes that have had issues in the past. 516222, 475481, 475480, 43266, 52798. If I boot the hub it clears the issue and has for the above nodes. Current node having issues is 50141 last time I check. It can connect to other nodes. The best way to recreate the issue to connect a node on your home internet and connect it to the cloud hub. Now take this node mobile and run it off your phone in a car mobile. It will now not be able to connect to the hub, till the hub is booted. Its the change in dns/ip that seams to be linked to the issue. Never have had this issue on a non cloud hub.
I can only generically say that I have had issues with cell/mobile DNS but I canât say that is your issue.
I just bought service with other carrier to fix my issue. Many 3rd tier providers have more issues because they have lower priority on cell tower channels.
When you are cell mobile, your ip address can change rapidly, most especially if you are near the boarder of cellular districts. So if that is a problem, a service like a rapidly updating dynamic dns may help.
Because âifâ your target server does not have a copy of your node# & correct ip , it will not allow connect.
You will need to look at your logs to have a window to what might be happening. To many possibilities from your description.
No. The client registration string does not change. DNS is populated by the ASL registration server. You can lookup any ASL node with <node#>.nodes.allstarlink.org.
Mike in my case I run both registrations so thatâs a rabbit hole. It is not just mobiles, it was an example. I find non Hamvoip nodes have this issue more often and repetitive.
