Let me preface by stating my password is correct in iax.config and the node is registered which CLI acknowledges.
CLI is stating the following message: NOTICE[363]:chan_iax2.c 9949 socket_process: registration of ‘548272’ rejected: ‘Password incorrect’ from 162.248.92.131.
I am using a BCR repeater with an RC-210 controller and a Repeater-Builder node. The software is from Hamvoip.org. I have been through all the troubleshooting procedures as outlined in Allstar Wiki without success. Additionally, I am using port 4570 in all the defined parameters.
Yes, 4570 is registered correctly with Allstarlink.org and is specified in all software parameters. I also noticed 162.248.92.131 is the Allstarlink.org image download file; however, I am using the image from Hamvoip.org
There are no extraneous lines that I can find in the iax.conf file. The only changes I made to this file are:
bindport=4570
register=>548272:mypassword@register.allstarlink.org
I am not sure why there is a “greater than” sign but removing it does not make any difference. I still receive the same error message.
I am not attempting to do anything. I am just letting CLI run and watch the output. DNS lookup works fine but this message keeps popping up every so often without my intervention; I’m not issuing any CLI commands. I believe if I can solve this, it will also solve the connection problems: outbound and inbound. I cannot find any reference regarding NOTICE[363]. Iax port and password are correct in node and server settings.
The “>” sign is in the image software https://hamvoip.org/RPi2/RPi-Z2W-2-3-4_V1.7-01_Allstar.exe in the iax.conf file.Upon editing the iax.conf file the line appears exactly like this: ;register => xxxxxx:pppppppp@register.allstarling.org, where xxxxxx is the node number and pppppppp is your password. So I uncomment this line and fill in the required information. But as I stated before, removing the “>” and just have “=” does not solve the problem. Notice[363] keeps appearing.
To my knowledge, the > is not required in the registration string
But should not hurt anything.
The ip of the reject connection is the allstarlink server.
It could be an issue with a mirror server. I think there is some redundancy built in.
So what I guess I am thinking is that ‘if there is no functional issue’,
don’t sweat it.
It’s not likely an error on your end.
But if you loose registration for some reason and I have seen that you are indeed registered, that would be an issue.
Thank you for the response. I created another image for the Hamvoip.org and populated the required parameters with the same “NOTICE” result. I have since changed to the Beta version from Allstarlink.org running on a Pi 4B which is a more polished software for Allstar. The result: the aforementioned NOTICE is resolved. Thank you again for your comments.
