I recently installed SkywarnPlus in two Shari 818 node and apparently is working fine, however I have a flood warning alert stuck there and could not figure out on how to either reset it or delete it.
It is not a test alert, but one that came from Skywarm itself.
Changing between Onset and Effective alert type makes no difference.
I was wondering if there is a way to clear out these alerts.
If you reboot and it comes back the National weather service is still issuing a flood warning for your county region some where. They are temp files so rebooting wipes them. Skywarn every 5 minutes checks the NWS for warnings. Check the weather service see if they are still issuing the warning.
