Clear Node Node 542580 / 542581
Asterisk Version: 22..x.y+asl3-3.n.m
ASL3 Version: 3.x.y
Inquiry
Clear Node can not connect to the server. It is programmed correctly, Wi-Fi was properly checked, and I noticed that my Node is not registered. Could this be an issue?
Your node is not authentication/registering to the system. Most likely your node password is incorrect.
So, how do I correct the password vs log in pw?
ClearNodes have their own admin interfaces. You'd need to contact NodeVentures for support. It's in the app somewhere. I've never owned one so I don't know.
