Hello, ...
Issues with audio on ASL 1.01 GIT version 004b9dd
Usually issue clears up after reboot, was happening every few months, now
seems every day/few days...
This does not appear to be network issue, as ID's and courtesy tones, local
audio files, are also impacted.
Using DSP aka usbradio
issue is heard even via phone portal
using standared URI
Single Node
4.9.0-6-686-pae Kernel
Intel Atom CPU 1.8Ghz
2GB Ram
SSD
*load average: 0.12, 0.07, 0.02*
*Logs show:*
*[Jan 27 11:55:49] WARNING[372] chan_usbradio.c: Loaded parameters from
usbradio_tune_usb_27038.conf for device usb_27038 .*
*[Jan 27 11:55:49] WARNING[370] chan_usbradio.c: Possibly stuck USB read
channel. [usb_27038]*
*[Jan 27 11:55:49] WARNING[370] chan_usbradio.c: Nope, USB read channel
[usb_27038] wasn't stuck after all.*
*[Jan 27 11:55:49] NOTICE[372] chan_usbradio.c: USB Adapter has no EEPROM
installed or Checksum BAD on channel usb_27038*
*Dmesg:*
*[ 314.006920] **perf**: interrupt took too long (2507 > 2500), lowering
kernel.perf_event_max_sample_rate to 79750*
*[ 366.570103] **perf**: interrupt took too long (3169 > 3133), lowering
kernel.perf_event_max_sample_rate to 63000*
*[ 429.870947] **perf**: interrupt took too long (3963 > 3961), lowering
kernel.perf_event_max_sample_rate to 50250*
*I have been restarting weekly, and the issue is only getting worse, any
thoughts?, Is there a newer version of ASL?*
*Thanks,*
*Mark*
rpt-audio.m4a (107 KB)
