First, I must thank everyone involved with developing this system. It has brought me countless days of fun and frustration, all worthwhile.
FWIW, this is my arrangement with a GM300 modded to 32 channels and a URIx. Without the influence of the URIx the radio always reverts to the last channel set by the CHANNEL button, not the one set via steering. I have not had occasion to test that in a brown-out circumstance. Regardless, initial channel after reboot is set to #1 by simpleusb.conf, snippet below. Note there are five lines available from the URIx and five available on the radio via S/W. I have not yet bothered to define the last 16 available. While all this seems to work fb on the bench, there will be a camera pointed at the radio display when deployed to the mountaintop in a few days. I hope this helps someone and that my approach is not too backasswards.
Ross ve6ars
; simpleusb.conf
[general]
[usb]
gpio1=out0
gpio2=out1
gpio4=out1
gpio5=out1
gpio6=out1
;Then from rpt.conf:
[xxxxx] ; Change this to your assigned node number
rxchannel = SimpleUSB/usb ; Rx audio/signalling channel for simpleusb
duplex = 0 ; add this or the simplex radio tx’es when signal present
functions=functionsxxxxx ; Repeater Function Table
macro = macrosxxxxx ; setup macro stanza definition
[functionsxxxxx]
5=macro ;this means that you type *5 and then the number of the macro from [macrosxxxx] stanza
;freq agile remote channel steering setup
6011=cop,62,GPIO1=0
6021=cop,62,GPIO2=0
6031=cop,62,GPIO4=0
6041=cop,62,GPIO5=0
6051=cop,62,GPIO6=0
6012=cop,62,GPIO1=1
6022=cop,62,GPIO2=1
6032=cop,62,GPIO4=1
6042=cop,62,GPIO5=1
6052=cop,62,GPIO6=1
[macrosxxxxx]
; ****************** Freq agile remote macros *************
501=6011602260326042*6052# ; channel 1 wx
502=6012602160326042*6052# ; channel 2 ve6aah
503=6011602160326042*6052# ; channel 3 ve6rot
504=6012602260316042*6052# ; channel 4 ve6cam
505=6011602260316042*6052# ; channel 5 ve6ryc
506=6012602160316042*6052# ; channel 6 146.52 simplex
507=6011602160316042*6052# ; channel 7 ve6cnp
508=6012602260326041*6052# ; channel 8 146.94 -600
509=6011602260326041*6052# ; channel 9 ve6oil
510=6012602160326041*6052# ; channel 10 ve6hrb
511=6011602160326041*6052# ; channel 11 wx
512=6012602260316041*6052# ; channel 12 wx
513=6011602260316041*6052# ; channel 13 wx
514=6012602160316041*6052# ; channel 14 wx
515=6011602160316041*6052# ; channel 15 Dahl rptr
516=6012602260326042*6051# ; channel 16 MDWC
