I have a node setup with a RPi. It is configured on my home network SSID. I am traveling and too the node with me. IS there a way for me to reconfigure the SSID without being connected to a network? When I power the unit up it will obviously not connect to the WIFI at my remote location bcs the credentials are not programmed in.
I would like to avoid reprogramming the unit jsut to change the SSID.
Do you know the credentials but just can't see it or do you not know? In the former, you can easily add a network just by its name and passkey in Cockpit. In the latter, can you pair it to your phone as a hotspot tether and when you get there, then reprogram it from your phone.
Right now I have re flashed the SD card with the credentials from the new location. I am not able to see the RPi on the network though I am sure the SSID and PW are correct.
Easy: configure your phone hotspot to serve the node. When you get to the location, connect a laptop to the same hotspot and configure on-site.
Easy: get a travel router. Configure the node to connect to it, also your laptop. Connect to the local Wi-Fi, use the laptop if necessary to get on their Wi-Fi.
Less easy: obtain a small monitor and keyboard, take them along and configure on-site.
Less easy still: configure your laptop with Internet Connection Sharing and connect it to the node, configure on-site.
