HI All,
Anyone out there has done an interface between the cat 200b controller and DMK URI.
Wayne
HI All,
Wayne
I have used cat1000 and app_rpt with PP interface.
It's all basically the same.
Using the remote base interface,
Invert the logic
COS -PTT
PTT - COS
TXaudio - RXaudio
RXaudio - TXaudio
Inverting the logic on the cos/ptt may require a transistor to make a double
inversion. 2n2222 /3904/3906
I can't remember what I used. Just that one problem you will see is getting the
proper signal from lines that FLOAT when active or inactive. Hence the transistor.
...mike/kb8jnm
HI All,
DMK URI.Thanks
Wayne
This email has been checked for viruses by Avast antivirus software.
Download Free Antivirus Software | Avast 2024 PC Protection
http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-usersTo unsubscribe from this list please visit
http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users and scroll down to the
bottom of the page. Enter your email address and press the "Unsubscribe or edit
options button"
problem.
Wayne,
Did you get it to work without a transistor? If you had to use one, how did you hook it up?
Im trying to do the same thing
A PTT line does not make a good COS line for the interface to a sound fob or vv.
PTT line on the controller is no voltage / float when inactive and switches to ground, still 0v when active.
This is why you need a transistor to invert that signal to a positive voltage the sound fob can work with.
Any chance of a diagram of how i would wire the transistor up?
