cant ping or traceroute to register.allstarlink.org
OK, it wasn't in modules.conf, but had to add a dnsmgr.conf file now shows "Y" but still no register.
tried to ping the server, didn't work.
Tried traceroute also no go, should I see it or does it block icmp?
[root@2360 asterisk]# traceroute 44.98.254.145
traceroute to 44.98.254.145 (44.98.254.145), 30 hops max, 38 byte packets
1 homeportal (192.168.1.254) 7.593 ms 6.354 ms 9.444 ms
2 108-198-88-1.lightspeed.rcsntx.sbcglobal.net (108.198.88.1) 33.393 ms 24.639 ms 23.120 ms
3 71.155.112.230 (71.155.112.230) 28.088 ms 30.553 ms 26.064 ms
4 * * 70.143.193.126 (70.143.193.126) 29.092 ms
5 12.83.80.185 (12.83.80.185) 36.344 ms 12.83.80.189 (12.83.80.189) 36.245 ms 12.83.80.185 (12.83.80.185) 29.868 ms
6 gar25.dlstx.ip.att.net (12.122.85.233) 30.305 ms 30.601 ms 31.341 ms
7 192.205.36.222 (192.205.36.222) 29.046 ms 29.070 ms 29.989 ms
8 be2764.ccr32.dfw01.atlas.cogentco.com (154.54.47.213) 32.496 ms be2763.ccr31.dfw01.atlas.cogentco.com (154.54.28.73) 27.303 ms 26.848 ms
9 be2441.ccr41.iah01.atlas.cogentco.com (154.54.41.65) 35.356 ms 33.722 ms 35.345 ms
10 be3302.rcr21.msy01.atlas.cogentco.com (154.54.81.86) 40.227 ms 41.719 ms 41.762 ms
11 be3303.rcr21.tpa01.atlas.cogentco.com (154.54.81.89) 62.391 ms 62.046 ms 58.817 ms
12 be2578.nr12.b005666-1.tpa01.atlas.cogentco.com (154.24.16.98) 71.652 ms 67.870 ms 64.507 ms
13 38.140.225.146 (38.140.225.146) 66.960 ms 64.501 ms 67.099 ms
14 66.216.50.34 (66.216.50.34) 59.505 ms 59.802 ms 60.373 ms
15 ASL-hv.keekles.org (199.47.174.141) 63.397 ms 58.017 ms 57.555 ms
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 * * *
27 * * *
28 * * *
29 * * *
30 * * *
This email has been checked for viruses by AVG.
working from here
C:\Users\XX>tracert register.allstarlink.org
Détermination de l’itinéraire vers register.regsvcs.allstarlink.org [44.98.254.145]
avec un maximum de 30 sauts :
1 29 ms 3 ms 1 ms 192.168.1.1
2 17 ms 18 ms 13 ms modemcableXX.XX-56-74.mc.videotron.ca [74.56.XX.XX]
3 14 ms 18 ms 19 ms 10.170.154.XXX
4 44 ms 64 ms 46 ms 216.113.126.XXX
5 45 ms 38 ms 64 ms eqx.20ge.iad.bboi.net [206.126.236.47]
6 90 ms 56 ms 61 ms atl-ten3-1-ash-ten3-1.bboi.net [66.216.1.157]
7 51 ms 52 ms 54 ms 66.216.2.10
8 53 ms 78 ms 56 ms 66.216.50.34
9 55 ms 71 ms 51 ms ASL-hv.keekles.org [199.47.174.141]
10 58 ms 53 ms * register-tpa.allstarlink.org [44.98.254.145]
11 58 ms 59 ms 60 ms register-tpa.allstarlink.org [44.98.254.145]
Itinéraire déterminé.
(using a french windows) that why it show response in french)
XX to protect some private info
Le lun. 13 août 2018 à 15:03, George Csahanin george@dyb.com a écrit :
OK, it wasn’t in modules.conf, but had to add a dnsmgr.conf file now
shows “Y” but still no register.
tried to ping the server, didn’t work.
33.722 ms 35.345 ms
41.719 ms 41.762 ms
62.046 ms 58.817 ms
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 * * *
27 * * *
28 * * *
29 * * *
30 * * *
https://www.avg.com
You’ll need to fix ping to register.allstarlink.org. Maybe check if you can ping your router and go from there?
Tim WD6AWP
If he can traceroute out of his router (like we can see from his second hops) he cant fix much on his side. Unless he have an ampr gateway badly configured
33.722 ms 35.345 ms
41.719 ms 41.762 ms
62.046 ms 58.817 ms
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 * * *
27 * * *
28 * * *
29 * * *
30 * * *
https://www.avg.com
Tim WD6AWP
I agree. However it is up and I can ping it:
ping register.allstarlink.org
PING register.regsvcs.allstarlink.org (44.98.254.145) 56(84) bytes of data.
64 bytes from register-tpa.allstarlink.org (44.98.254.145): icmp_seq=1 ttl=53 time=59.5 ms
64 bytes from register-tpa.allstarlink.org (44.98.254.145): icmp_seq=2 ttl=53 time=59.6 ms
64 bytes from register-tpa.allstarlink.org (44.98.254.145): icmp_seq=3 ttl=53 time=59.7 ms
64 bytes from register-tpa.allstarlink.org (44.98.254.145): icmp_seq=4 ttl=53 time=59.1 ms
^C
register.regsvcs.allstarlink.org ping statistics —
4 packets transmitted, 4 received, 0% packet loss, time 3004ms
rtt min/avg/max/mdev = 59.151/59.521/59.731/0.375 ms
Tim WD6AWP
Maybe his resolver is messed up?
Tim WD6AWP
Never mind the resolver comment, that was wrong. What the IP of the station that can’t ping. Is it on this list? http://lists.allstarlink.org/pipermail/app_rpt-users/2018-August/019206.html
Tim WD6AWP
By the way the 2 nodes that I use to take care of are online and registering and they run on Acid.
No reboot, no resolving stuff.
The only thing I could think of that make bad registration are either cross port fowarding or bad router.
I really dont get it if you have a service at port 4569 inside your network, why would you foward the traffic from port 4570 to it. Thats looking for trouble. The software can be configured to run on different port and it will react to it perfectly, why risk trouble and mess with the port?
^C
33.722 ms 35.345 ms
41.719 ms 41.762 ms
62.046 ms 58.817 ms
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 * * *
27 * * *
28 * * *
29 * * *
30 * * *
https://www.avg.com
Tim WD6AWP
Tim WD6AWP
Tim WD6AWP
Tim WD6AWP
