Can't login, node links on dashboard
I'll admit to not taking good notes as I progressed and I'm not much of a manual reader. I spent much of yesterday building a Shari Pi5 node and trying to configure it by following along with a couple videos. I believe I have it completed as I can use my HT and log in to the parrot node (55553) and it all works as expected. I figured out how to do the DTMF tones to do this as I can't get logged into the Allmon3 dashboard Node Links section so I can do commands from there. It wants a username and password that I don't recall setting up. I found that the default login is allmon3 and password but that doesn't work. I tried my username and password to access Web Admin Portal but that doesn't work either. I'm not finding a place to reset this password on the login page. I tried the username for my node and the password that Allstar generated and that isn't it. Most of the usernames and passwords I created yesterday were automatically saved by my pc but not this one.
I'm lost! How do I figure this out?
Thanks, Matt
NE9D
UPDATE!!!!
Last evening, I was following Grayman POTA's video. Towards the end of his video he showed how to reset the password. I tried to do this but it came back with an error when I tried to delete it. Apparently it still deleted it. I went back in and redid the password reset like he showed and this time it all worked just like it did for him. Using the new password I reset to got me in and I can now use all the node commands in the Node Link menu!
Sorry for the post as I figured it out myself. Wasn't sure if I should just delete the entire post or let it be part of the searchable history and maybe help someone else out.
Thats ok. Sometimes you got to do something different to find this issue or in this case right it out to find it. Allmon3 is great but I recommend you check out Allscan or Yaamon. It's basiclly another type of dashboard for ASL3.
setting up allmon3 is covered in the AllStarLink Manual.
there is little to do other than create a user and password just for allmon3, especially if you use the ASL3 Appliance image.
details are found in User Management - AllStarLink Manual
