Can't log in to allmon3
Im disabled and partially blind i need help changing a amon3 password so i can use my allstar node can someone please help me? Siri64@comcast.net thank you
Have you looked over User Management - AllStarLink Manual
Hi,
I would like to add that you might need to add sudo to the command in the link that @WA3WCO mentioned. For example, to change password for user allmon3, enter the following command in your CLI
sudo allmon3-passwd allmon3
It will ask for new password and then again to confirm it. It is highly recommended to change your default user and password if exposing to the internet. The link provided by WA3WCO goes over that.
Regards,
Adam
