RepeaterPhone can connect to other nodes but does not register itself as a node.
Setting up an AllStarLink server/node on a Raspberry Pi should register as a node. If you have the server/node running but it does not show as registered then, as already suggested, please exec the sudo asl-node-auth-check command and post the results.
