Can't Get Node to Register
When I log into AllStarLink.org and check the Status of my Node, 675430, it says it is unregistered and was last registered on a date that makes no sense. Looks like it is sometime later today??? Not sure how I unregistered it if indeed I did. Well, anyway, looking for some advice on how to fix it. Resubmitting the Node doesn't do anything.
John Walker, K9SVL
Time is in Zulu/GMT.
Run sudo asl-node-auth-check and post the results.
Robert,
How do I do that?
Johnny
Sent from Yahoo Mail for iPhone
On Monday, November 2, 2026, 21:59, Robert Gaynor [email protected] wrote:
Someone replied to your post.
| KK6RQ
November 3 |
Either from the terminal through Cockpit or ssh into your node.
What did you mean, "resubmitting the node"..?
The node was previously registered and working. Now it doesn’t. Do I have to have a physical Linux server up and running?
What type of node do you have?
How is your node / system connected to the network?
or are you using an app?
Well, I didn’t have a server running for the node. I set one up on a pi 3b+. Now it works with RepeaterPhone but AllStarLink still shows it unregistered. I’ve been reading through the manual and figuring things out slowly. I don’t think this is 100% solved yet. John K9SVL
| WA3WCO ASL Community Admin
November 3 |
RepeaterPhone can connect to other nodes but does not register itself as a node.
Setting up an AllStarLink server/node on a Raspberry Pi should register as a node. If you have the server/node running but it does not show as registered then, as already suggested, please exec the sudo asl-node-auth-check command and post the results.
Allen, I think I can give that a try now. You folks have been very helpful. I will post the results, probably sometime tomorrow. John K9SVL.
November 4 |
Here is what I got when I ran `sudo asl-node-auth-check. ```
-----===== AllStarLink Node Authentication Check =====-----
Checking configuration:
Info: Skipping evaluation of private node 1999
Info: rpt.conf has configuration for:
Info: /etc/asterisk/iax.conf contains no registration lines.
Info: /etc/asterisk/rpt_http_registrations.conf contains 1 registration line(s)
Info: Registrations present for configured node(s): 1234
Error: No configuration present for registrations for node(s): 1234
Error: Cannot continue; reconcile configuration before proceeding
Just point me in the right direction and thanks once again for all of the help.
John K9SVL
Sent: Tuesday, November 3, 2026 8:07 PM
To: [email protected]
Subject: AllStarLink Community Forum: Can't Get Node to Register
November 4
It looks like you have not yet configured your node.
Please review the ASL Manual : ASL3 Installation
I did configure a node. Up and running and I can link to other nodes using RepeaterPhone. John K9SVL
