Can't connect to remote nodes
I'm having an issue with my public node not being able to connect to any remote nodes.
-----===== AllStarLink Node Authentication Check =====-----
Checking configuration:
Info: Skipping evaluation of private node 1950
Info: Skipping evaluation of private node 1951
Info: rpt.conf has configuration for: 67891
Info: /etc/asterisk/iax.conf contains no registration lines.
Info: /etc/asterisk/rpt_http_registrations.conf contains 1 registration line(s)
Info: Registrations present for configured node(s): 67891
Info: IP from https://conntest-east1.allstarlink.org/ip reports: 24.222.168.238
Info: IP from https://conntest-west1.allstarlink.org/ip reports: 24.222.168.238
Info: IP from https://conntest-west2.allstarlink.org/ip reports: 24.222.168.238
Info: IP from udp://conntest-east1.allstarlink.org:4570 reports: 24.222.168.238
Info: IP from udp://conntest-west1.allstarlink.org:4569 reports: 24.222.168.238
Info: IP from udp://conntest-west2.allstarlink.org:4569 reports: 24.222.168.238
OK: HTTP IP probes have consensus on the same perceived IP
OK: IAX IP probes have consensus on the same perceived IP
Testing node 67891:
OK: Node registration config is well-formed
OK: Node registration type is HTTP
OK: register.allstarlink.org is reachable (via HTTP)
OK: HTTP registration state is Registered
OK: Perceived IAX IP:PORT for this node is: 24.222.168.238:4569
OK: Registered to aws-east1a-register0.allstarlink.org - 52.20.63.146
OK: Server-set UDP port matches bindport in iax.conf
OK: Node registration within 10 minutes: 2026-08-17 03:19:39 UTC
Info: Last time IP changed was 2026-06-06 06:12:02 UTC
Warning: Node is not perceived as registered; not tested
Warning: Node 67891 has 1 warning(s)!
Warning: Warnings may or may not be problems depending on configuration
When I try connecting to a remote node I get this
[2026-08-16 21:34:06.701] NOTICE[810]: chan_iax2.c:4830 __auto_congest: Auto-congesting call due to slow response
-- Remote UNIX connection
-- Remote UNIX connection disconnected
[2026-08-16 21:34:34.699] WARNING[806]: chan_iax2.c:3645 __attempt_transmit: Max retries exceeded to host 104.232.32.242 on IAX2/104.232.32.242:4569-576 (type = 6, subclass = 1, ts=2, seqno=0)
I have my port forwarding setup, I can connect to a local node on the same computer.
After some troubleshooting it appears to be an authentication issue. My node is not perceived as registered. Where do I go next in my troubleshooting?
Sean, VE6SAR
