When i select the icon “EXECUTE LINKIN COMMANDS”. i SELECT THE CONNECT COMMAND, ENTER THE NODE NUMBER, AND YES OR NO CHOICE. THE “EXECUTE” COMMAND IS NOT THERE FOR ME TO APPLY THE COMMAND. IN ANOTHER WORDS I CAN’T NOT CONNECT TO ANYBODY.
CAN ANYBODY TELL ME WHAT IS WRONG WITH MY SETTING. THANK YOU.
Please provide additional information or screenshots. It’s unclear what you’re asking/reporting here.
If you notice there is not EXECUTE command. Therefore i can’t connect to that node or any other node that i want. Thank you.
That’s very odd and almost looks like your browser is blocking it. What is this little drop-down here? That isn’t part of Allmon3.
You are write, my browser was blocking Allmon3 from working.
I switched browser from Edge to FireFox and the problem ended.
That little drop-down only show when i are using Microsoft Edge browser.
Thank you for your help.
Are you running some sort of unusual adblocker or some sort of tool that “processes” JavaScript (like NoScript)? I see that little drop down in Edge after the last code update that I’ll need to look at. But there isn’t anything else broken in Chrome/Edge I can see. Want to make sure I understand what about your setup broke it.
