I just built a cloud-based ASl node (hosted on Vultr)
I am using the ASL 2.0.0 Beta 6 version
It is showing “green” as registered but I cannot get the node to report statistics.
the stats page gives the following message
“Node is not reporting statistical data or is offline.”
I have read other articles here with similar issues however one was a password issue and the other didn’t seem to be my issue either.
I found in another post that I need to add the following to my rpt.conf:
statpost_program=/usr/bin/wget,-q,–timeout=15,–tries=1,–output-document=/dev/null
and also my statpost_url address was missing the .php
once I made these changes the stats page went back to the original message "Node is not reporting statistical data or is offline.”
If your node was an NNX node in the 60000 block, this problem was likely on the server end. The stats server was denying those nodes resulting in a 422 error. The problem has been corrected. I apologize for the inconvenience.
