So, the most important question to answer is, Why was his rc.updatenodelist not running / working?
Any ideas so that we can learn from this issue.
From: George Csahanin via AllStarLink Discussion Groups [mailto:noreply@community.allstarlink.org]
Sent: Friday, October 09, 2020 10:35 AM
To: ke6pcv@cal-net.org
Subject: [AllStarLink Discussion Groups] [App_rpt-users] Cannot connect to only certain nodes but the allstar boxes can see each other
George_Csahanin
October 9
See my last post. We figured it out. His rc.updatenodelist wasn’t running so he didn;t get my new (as of Sunday) IP address. My Inet connection was down a day due to a cable cut and when re-established I got a new IP address
GeorgeC
In Reply To
jfall
October 9
Hi There, Probably easy answer. You can’t get into W8VT’s hub node in NJ 43015. That is because he probably is using a firewall to screen unknown IP’s. So ring him up or email him and tell him you got a new IP address. Because DNCP on your ISP gave you a new one. Problem solved.
Previous Replies
jfall
October 9
Hi There,
Problem solved.
wd6awp ASL Admin
October 7
I’ve run into this also, and I find the updatenodelist dies at times, but I thought I was the only one
Do systemctl enable updatenodelist
to enable it on server boot.
Here are other useful systemd commands:
systemctl start updatenodelist
systemctl restart updatenodelist
systemctl status updatenodelist
systemctl stop updatenodelist
systemctl is-active --quite updatenodelist
That last command is useful in a script. For example I rewrote astup.sh, astdn.sh and asters.sh to use it.
#!/bin/bash
# N4IRS 07/26/2017
# WD6AWP 09/09/2020
systemctl is-active --quiet asterisk.service
err=$?
if [ $err -eq 0 ]; then
echo "Asterisk is currently running!"
else
echo "Starting asterisk..."
systemctl start asterisk.service
fi
You use that (or write a similar script) and call it with cron to start it once a day if dead.
BTW, here’s the service file if you need it. Put this in the directory with filename shown then do a systemctl daemond-reload
#/lib/systemd/system/updatenodelist.service
[Unit]
Description=AllStar NodeList updater
Wants=network.target
After=network-online.target
BindsTo=asterisk.service
[Service]
Type=simple
StandardOutput=null
ExecStart=/usr/bin/rc.updatenodelist &
ExecStop=/usr/bin/killall -9 rc.updatenodelist
# safe_emulation
Restart=always
RestartSec=10
[Install]
WantedBy=multi-user.target
George_Csahanin
October 7
I think I just found the problem. in /lib/systemd/system there is a file “updatenodelist.service”
Contents:
root@repeater:/lib/systemd/system# more updatenodelist.service
#/usr/lib/systemd/system/updatenodelist.service
[Unit]
[Service]
Type=simple
StandardOutput=null
ExecStart=/usr/local/bin/rc.updatenodelist &
safe_emulation
Restart=always
RestartSec=10
[Install]
So not sure why it wasn’t starting unless network.target is an issue somehow
I have a hard time wrapping my head around systemd. Used only Slackware Linux since pre-version 1 back to 1994. Much easier to understand.
GeorgeC W2DB
George_Csahanin
October 7
Problem…here’s the /usr/lib/systemd directory:
root@repeater:/usr/lib/systemd# ll
total 28
drwxr-xr-x 7 root 4096 Feb 26 2020 .
drwxr-xr-x 70 root 4096 May 17 18:28 …
drwxr-xr-x 3 root 4096 Feb 26 2020 boot
drwxr-xr-x 2 root 4096 Feb 26 2020 catalog
drwxr-xr-x 2 root 4096 Jul 5 2017 network
drwxr-xr-x 4 root 4096 Mar 2 2020 user
drwxr-xr-x 2 root 4096 Jul 5 2017 user-generators
Just found it in /lib/systemd/system. Here’s what’s inside:
root@repeater:/lib/systemd/system# more asterisk.service
#/usr/lib/systemd/system/asterisk.service
[Unit]
Description=Asterisk PBX and telephony daemon
Documentation=man:asterisk(8)
BindsTo=dev-dahdi-pseudo.device
Below requires a addition to udev rules# See /etc/udev/rules.d/dahdi.rules
After=dev-dahdi-pseudo.device
[Service]
Type=simple
StandardOutput=null
ExecStart=/usr/sbin/asterisk -g -f -C /etc/asterisk/asterisk.conf
ExecStop=/usr/sbin/asterisk -rx ‘stop now’
ExecReload=/usr/sbin/asterisk -rx ‘module reload’
safe_asterisk emulation
Restart=always
RestartSec=10
[Install]
GeorgeC
Tom
October 7
George,
It runs as a systemd service (daemon). Look in /usr/lib/systemd/system/asterisk.service to see how it is defined.
Tom
··· (click for more details)
