Cannot connect to my new node with Repeaterphone
I cannot connect to my new now with Repeaterphone any advice or help would be welcome. My node shows up in the the allstar link registery. It dials and then times out.
Allow WebTransceiver/RepeaterPhone/DVSwitch access is set to yes.
Please let me know if anyone has any advice.
Best,
Dan
Almost always a port-forwarding problem. Please run asl-node-auth-check.
What's it listed under..? I don't see an account for KD3CYC...
W3KZX I jut got my vanity license approved yesterday. The node was KD3CYC yesterday when I posted. I turned my radio of this morning while at work, but the node is still on and active. Thank you. I will work on port forwarding this week and see if things get better. Here was the result of asl-node-auth-check. Thank you for your help!
Which one should be configured to sue repeater phone? iax.conf, or opt_http_registrations.conf? Maybe you just helped me find the issue?
Best,
Dan
I commented out the iax registration and ran the command again. Here are the results.
Looks like you're hitting one of the bugs in asl-node-auth-check. I wish I'd made that a standalone package rather than bundled in asl3.... Please do the following:
sudo wget -O/usr/bin/asl-node-auth-check https://repo.allstarlink.org/hotfix/asl-node-auth-check
sudo chmod 755 /usr/bin/asl-node-auth/check
sudo /usr/bin/asl-node-auth-check
Downloaded and ran the file you suggested, here are the results:
Thanks guys I am in now with repeater phone! Thank you for your help!
Well, what did you do to get it going?
