I just finish building a new Hotsot wanting to setup on 220mhz. Locally I can get to terminal, Allmon3 issue commands from allmon3. From the wild nothing. I tried to use node remote from a completely different mode. Nothing on Node remote I get connection failed. On Repeater Phone it times out. What Ami missing. What port/s do I need to forward? Any help appreciated!
Need to port forward 4569 this will allow others to connect to your node or use Zoiper/DVSwitch/Repeater Phone
Port Forward 80 to access Almon/Supermon
to access the Node from another Node need to Port forward 5038
Need to set the password in manager.conf
Also need to change the the bindaddr
this............. bindaddr = 0.0.0.0
Assuming you're talking about a modern ASL3 install, the only port you MUST forward inbound is UDP/4569 (or something else if you changed it). If you want Allmon3 access forward in port 443. If you need cockpit admin, port 9090.
