How Do I install All-Star ASL three To work with a radio less hub node that I could use RepeaterPhone to dial up to And. Whoever else wants to connect to the hub can also can connect..
It's all about the channel driver, and duplex mode. Set in rpt.conf
rxchannel = dahdi/pseudo ; No radio (hub)
; rxchannel = SimpleUSB/usb_48233 ; SimpleUSB
; rxchannel = Pi/1 ; Raspberry Pi PiTA
; rxchannel = Radio/usb_48233 ; USBRadio (DSP)
; rxchannel = Dahdi/1 ; PCI Quad card
; rxchannel = Beagle/1 ; BeagleBoard
; rxchannel = USRP/127.0.0.1:34001:32001; GNU Radio interface USRP
duplex = 2 ; 0 = Half duplex with no telemetry tones or hang time.
; 1 = Half duplex with telemetry tones and hang time. Does not repeat audio.
; This mode is preferred when interfacing a repeater.
The rest are settings to your specific liking for your node.
See repeaterphone for their specific instruction.
Thank you so much I’m
Going to try this right now.
I’m not the greatest when it comes to Linux I’m
Using Debian 12 and allmon I
Followed the instructions on the Allstarlink website for installing Debian 12 and Allmon on a Virtual Machine.
Did mostly copy and paste but it’s not hard for
Me because I grew up using DOS and Unix.
I really appreciate the effort that you took to get me closer to success.
Now should I do a fresh install and start over.
that way maybe you can walk me
Through this if you have no problem helping me with getting this worked out. My call is KQ4UPK my email is [email protected]
Do you have a
Node #
Maybe you won’t mind. Can do a simplex connection?
Chris, I do get unexpectedly busy, so I may disappear at any time. Life gets in the way.
Post your issues here and someone will help you through them if I don't.
I may not have the correct answers anyway LOL
