Bubble Chart node 535522
What s the problem to node of my friend his node is not connected to other node then when i click the bubble chart there is so many nodes connected
I’m seeing these connections:
Node Callsign Frequency CTCSS Location
29298 PHILIPPINE 97.4 ALLSTARLINK SYSTEM
53553 DU2R -RPTR 145.410 x-Band 100 UnitedStateOfAritao, PH
DU2R N/A N/A N/A N/A
29298 is connected to many nodes so the bubblechart shows those connections. Does that differ from his allmon or something?
yes right now his connected to that node is there a problem to bubble chart like my one node 43636 i cant use when i online that node there is always connected node even its online mode only
I will try to online my node 43636 and will see what happen today thank u robert for reply 73 4f2v phil allstarlink system node 29298 admin
Robert thank you 43636 is ok now 73
